What holds up your countertop extension ?
Discussion in 'Mystery Parts' started by MabelJ, Aug 25, 2014.
  1. MabelJ
    MabelJ Member
    109
    Aug 11, 2014
    The manual mentions that the trailer may be equipped with an extension. The front of our sink counter is hinged, but there is nothing to hold it up.
    What are we missing? Or is this piece hinged only to allow easy access to the pipes and stuff?
  2. speckhunter80
    4,782
    64
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Really would help if you would put the make model and year camper you have
  3. Unstable_Tripod
    14,279
    41
    May 20, 2008
    Seattle, Washington
    ^^Yes, and a picture. Various brands, models and years of campers had all kinds of differences in details like that.
  4. vinmaker
    vinmaker Member
    862
    Aug 22, 2014
    There is no bracket underneath? There should be. Obviously the thing is designed to be used and you cannot use a vertical countertop. You may need to contact the dealer to see if the factory just forgot to put a piece one it.
  5. MabelJ
    MabelJ Member
    109
    Aug 11, 2014
    It's a 1996 Rockwood Xl 1207
  6. speckhunter80
    4,782
    64
    Jul 26, 2012
    Don't believe that is a counter top extension but just a hinged access panel to get under the sink. What I would do is put a piece of plywood to create a shelf on the left side.
  7. MabelJ
    MabelJ Member
    109
    Aug 11, 2014
    Duh!
    I found out. The manual says it "may" have a support arm to be used as extra countertop. Ours does not. However I was in here with the cabinet down and lifting that hinged piece allowed me to still open the drawers! Voila - this is the reason for having a hinged panel and not just a solid front.
    Also, any kind of mod to use up that "dead air" space would need to be removable or be careful it doesn't interfere with lowering the cabinet fully. i.e. the "dead air space" is only there when it's up. A thin ply board horizontally only might work.
  8. Customer
    Customer Well-Known Member
    2,435
    246
    Jun 5, 2014
    and it only took a little less than two years? [:D]
  9. MabelJ
    MabelJ Member
    109
    Aug 11, 2014
    Yes,
    Giving her a more thorough go-around and cleaning. I'm up in all her little nooks and crannies and learning all her secrets.
