What if you don't have a heater?
Discussion in 'First Time & New Camper Owners' started by Two Bears, Feb 20, 2014.
  1. Two Bears
    Two Bears New Member
    67
    Jan 24, 2014
    I don't think our PUP has a heater, not sure yet, but wondering about using the small electrical heaters in one to knock out the chill. We used these in our tents and it worked great. Anyone else out there use them?
  2. friartuck
    friartuck Well-Known Member
    2,933
    136
    Nov 1, 2007
    Perry, MI
    Oh golly yes. [:D]
    Having a ceramic heater usually keeps us from having to run the furnace.
    If you add the camper make and model along with your tow vehicle information to the signature line we'll be able to better help.
  3. kitphantom
    12,344
    1,342
    Ditto on adding your pup to your signature line.
    Our previous pup did not have a furnace, so we used a small space heater several times on trips in cold weather. For us, that meant being sure we found a campground with power, since we usually dry camp. We also used an electric blanket or mattress pad.
    In the Cobalt, we have a furnace, so don't take the quartz heater as often, When we know it is likely to be under 20 or so, and we'll have power, we do take it as a supplement. Unlike many, the furnace noise doesn't bother us, but the extra fan and ability to aim the airflow in an area other than the furnace output is handy. Again, we take the electric mattress pad when we'll have power.
    Heat retention measures are important: throw rugs, PUGs, outside and inside (we only use the bunk end liners, the inside version, when the temps are really cold), curtains, something over the metal doorway (I use a piece of Polartec fleece).
    Here's a whole section dedicated to cold weather camping, whatever your definition of cold weather:
    http://www.popupportal.com/index.php?board=104.0
  4. pandpcamper
    pandpcamper Lifetime camper, newer to pup
    1,136
    Jun 25, 2012
    Those little ceramic heaters are great. We used 2 on one trip and got too hot! A hoodie or hat make a big difference in staying warm. We ran an extension cord from the electric box, plugging in to the extra outlet, due to the fact that 2 heaters will overload the inside power.
  5. CREEPPINGCHARLIE
    CREEPPINGCHARLIE CAMPING RECHARGES THE HUMAN MIND
    623
    Nov 14, 2007
    A lot of my camping is done around 8000 feet. If I am in a campground with electric, I use my ceramic heater instead of the furnance. It dors the job of keeping the PUP warm. [8D] [PU] [PUT]
  6. superbee73
    superbee73 New Member
    34
    Jun 13, 2013
    We have used electric blankets a couple times. Each person can adjust the temperature to their own liking. They are easy to pack and if its not too cold you use them as a regular blanket. The best part ... turn them on about 15 minutes early and you are climbing into a warm bed.
  7. frankvanw1
    frankvanw1 London, Ontario, Canada
    369
    Mar 18, 2009
    London, Ontario
  8. Snow
    10,965
    1,620
    Have two small heaters we use in the TT, one sits on the counter facing the back the other sits on the stove top facing the front.. We first bought the one heater about 4 years ago when we still had the pup and night time temps were dropping into the 40-50 degree range, try finding a small electric heater in a store at the end of August...
  9. chasw98
    chasw98 Chuck, Debbie, and grandson Jacob
    111
    Jan 1, 2013
  10. ChocoChock01
    4,022
    19
    Mar 7, 2012
  11. generok
    generok Well-Known Member
    2,848
    1,179
    Feb 7, 2013
    Anchorage, AK
    Yup, we use one too! Our oscillates and we place it in the middle of the PUP and it keeps both bunkends warm. Our PUP has a furnace, it will roast us out if we're not careful, but when it is just a little cool, and we have electric, we use the ceramic deal.
  12. tenttrailer
    3,493
    491
    Jul 18, 2013
    Thornville, OH
    Get one or two elec heater if your are camping with elect. If dry camping get a wave heater or a mr heater.
    I like the wave heaters because there is not battery and it's low pressure LP and can be connected to the quick disconnect of the stove propane line. Also, the wave is faster for two reasons its cooler and it's a catalytic heater. Downside of the wave models is the max BTU is 8,000 BTU where Mr heater had a 18,000 BTU unit. also, wave heaters are about 2X the price of Mr Heaters
  13. Two Bears
    67
    Jan 24, 2014
    Thanks for all the info and tips. I added our Truck and Camper, sorry about that, I am not that "techy" but will try to keep up [;)]
    Since we just got our camper 2 days ago, we will be spending our weekend checking it all out. We are excited to get this little guy on the road and get camping [CP]
  14. ChocoChock01
    4,022
    19
    Mar 7, 2012
    We can use our Mr Buddy w/o batteries as well (don't use the fan) and w the optional 20# hose connector which has a regulator on it provides low pressure, and connects to 20# or smaller w proper connector tank or can use 1# cannisters.
  15. yetavon
    3,376
    217
    Mar 11, 2010
    Western NC
    Snuggle closer.... [;)]
    We use a Parabolic Heat Dish. It worked fine in the Pup without a heater and in the HTT it keeps the furnace from running in all but the coldest temps.
  16. Two Bears
    67
    Jan 24, 2014
    Found out today we have a heat strip, that should help! Thanks for all your responses!
  17. PNW Family
    PNW Family New Member
    1,015
    Dec 3, 2012
    I'm just going to throw out a no-tech solution, just because I can. [:D]
    A large microfiber or fleece blanket. It'll add about 15-20 degrees of comfort rating to your existing bedding, without the use of batteries, power, or propane.
  18. kitphantom
    12,344
    1,342
    IIRC, most are not terribly impressed with the output of heat strips, they seem to more something to take the edge of a chilly day. However, if you aren't likely to encounter much colder than chilly weather, heat retention measures, warm clothes and bedding in addition to the heat strips may just be what you need.
  19. dav1966
    dav1966 New Member
    177
    Sep 6, 2010
    we have used a Mr heater big buddy heater for years in tents and the pop hook up to 20 pound tank that sits outside keeps us nice and warm
  20. Two Bears
    67
    Jan 24, 2014
    Yes, we camp year round in south Texas, and will carry a small heater for winter use! Thanks to everyone for all y'all's input
