What is the structure to mount to this roof? 2000 Starcraft Galaxy
Discussion in 'Miscellaneous Repairs & Maintenance' started by Plainsman, Aug 17, 2019.
  1. Plainsman
    Plainsman New Member
    Aug 17, 2019
    25332D90-469D-4204-A8CD-48913EE92E43.jpeg 054846EC-4E97-4C46-9E89-55A81E1DC7D0.jpeg 641609C3-ACDD-40D9-A8B6-64E1ED463E3A.jpeg 0119D3FC-71DA-4B6B-B597-B601DECE7493.jpeg 9A7702D0-D92F-4437-BDD5-E20785968A4B.jpeg DBA6DF06-8382-4CC2-B0B7-2C0A01C9DFF3.jpeg We just mounted a Swagman Roamer LT set of bars to our camper. Seemed to feel solid. Made it to a campsite with two Kayaks. Opened the camper, and looks like lag screws are just in the side panels of the roof! The lag screws came down tight and but hard. Feels solid. What could I be anchored in? Wondering if I need to move the mounts further inboard and use carriage bolts and a steel plate on the underside of the roof? Any advice welcomed! I’ll try to figure out how to upload something some pics from my phone. First timer poster here.
  2. joet
    4,818
    982
    I vote to move inboard and plate the underside
  3. Sjm9911
    4,917
    2,594
    Not much wood in these pups, bolt it and put plates on both sides.
  4. bheff
    bheff Well-Known Member
    1,026
    520
    Feb 24, 2011
    NW Arkansas
    If you move them, you will have 8 extra holes in your roof.
    Personally, I would have used some sort of block epoxied to the sideboard and roof then used bolts with a washer and nut.
    davekro likes this.
  5. Plainsman
    Aug 17, 2019
    Is there any metal support/structure right at the edges for most of these? I kind of supposed there was some sort of rigid frame along all the edges, and that the wood roof structure sort of fit in between it. Was hoping to hit metal rails along the roof edges, but not sure what is under there.
  6. davekro
    davekro Active Member
    410
    89
    Aug 30, 2019
    SF Bay Area, CA
    I think there is literally just 1/2”, maybe 5/8” particles board as side plates with the extruded exterior cover plate connecting the roof to the side plates. I like the earlier suggestion of epoxying and screwing plates or angle brackets to the verticle sides and mounting your frame to those. With as much bouncing as these trailers do, I would NOT trust the current mounts, especially with the weight and wind force the kayaks put on that rack. I’d look at angle alum or steel maybe 1.5” for the rack to mount to, with the verticle flange maybe even being wider. If it’s only 1 1/2” for both, you could just use a longer piece with maybe 3 to 4 thru bolted bolts,washers and nuts (nylock). Better to over engineer than under! Good luck.
