What is this port for on the side?
Discussion in 'Mystery Parts' started by Kasey Redrum, Nov 15, 2019.
  1. Kasey Redrum
    Kasey Redrum Member
    40
    27
    Oct 17, 2019
    I am confused, it appears that the port on the left is for the 30a plug, I can pull it out several feet, and push it back in. Now the port on the right? I can also see the cable back there as well (from the left port). What in the heck is the port on the right supposed to be for?? Is there something that should be going in or out of this empty port??? side hose - 1.jpg
  2. tombiasi
    6,639
    2,209
    The AC power cord is usually available from the port on the right. Don’t know what the one on the left is for.
    The black tag indicating it’s for AC is centered between the ports.
    PopUpSteve likes this.
  3. Raycfe
    17,761
    3,252
    If you look at the screws. The screws on the left are square drive. The factory uses this type. The other one has phillip head screws, different. I am guessing it was added so that something else could also be stored with the power cord. Maybe water hose?
    McSkippy and Anthony Hitchings like this.
  4. Kasey Redrum
    Kasey Redrum Member
    40
    27
    Oct 17, 2019
    So you think someone added in that port? Hiummm, maybe I should remove it and see if there is a treasure back there?? will keep you posted/
  5. tombiasi
    6,639
    2,209
    Are you related to Lt. Columbo?
    kcsa75 and neighbormike like this.
  6. bheff
    bheff Well-Known Member
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    The left is your 30amp connection . The right should have a smaller chord that connects to a plug on the side of your roof to power the A/C
    Tom Jordan and kitphantom like this.
  7. tfischer
    4,727
    2,338
    May 21, 2014
    Do you have an indoor/outdoor stove that goes in that general vicinity? Our Palomino Pony has a similar port where the gas line can be threaded though for "outdoor" mode. Ours is on the opposite side from the AC plug though.
    Tom Jordan likes this.
  8. Kasey Redrum
    Kasey Redrum Member
    40
    27
    Oct 17, 2019
    Ok so I removed the screws on the left side, and they are actually factory square drive screws. So not an add on. I couldnt remove the port as it was adhered to it with sealant. I did pull out the 30Amp cable, about 20 feet worth. Used a flashilight and nothing special inside there. So a bit perplexed over what the point pf a 2nd access point to the same cable is for. hummm.... I do not have Air Cond., but maybe there was an option for it, and this would be the space for it?? I am thinking about sealing it up with spray foam.
  9. tombiasi
    6,639
    2,209
    Tfischer suggested a propane hose. I am inclined to agree with that.
  10. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    This is on the driver side.....propane hose should be on the passenger side
    generok, kcsa75 and Orchid like this.
  11. tombiasi
    6,639
    2,209
    Why? My propane is on the street (driver) side.
  12. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    Dont fill it up, just keep the lid closed.
    kcsa75 likes this.
  13. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    I've never seen a propane connection on the driver side for a grill or stove. You would have to walk all the way around the camper to cook something
    Orchid likes this.
  14. tombiasi
    6,639
    2,209
    Mine is a 1998, perhaps someone wanted one there.
  15. Dingit
    Dingit Well-Known Member
    1,788
    1,267
    Mar 8, 2017
    All (most?) of the Rockwoods from that era have the double ports, if I remember from my shopping right. I don't know what it's for though. What is on the INSIDE? There are no secrets when you pop it up!
    ETA, I'm pretty sure it's for the AC, like mentioned above. You can use it for solar. It's a nice hole!
    ETA more, air conditioning that is, not the other AC
  16. Kasey Redrum
    Kasey Redrum Member
    40
    27
    Oct 17, 2019
    The propane is on the other side.
  17. Ladiesman
    Ladiesman Well-Known Member
    758
    541
    Feb 6, 2018
    I googled your pup and there was one on RV trader and it also has the side by side porta
  18. tombiasi
    6,639
    2,209
    Air conditioning is A/C. Alternating Current is AC.
    neighbormike likes this.
  19. tfischer
    4,727
    2,338
    May 21, 2014
    Why would the A/C wire run on the outside? I've never seen that (not that I've seen that many models lol)
    bheff likes this.
  20. bheff
    1,504
    930
    Feb 24, 2011
    NW Arkansas
    My last 2 pups did. Only guess is it's easier to have the customer pull out the plug and wire than to figure out how to have.a heavier gauge chord snake up through the canvas. 15740924239585546961160222597414.jpg
