what is this thing called a water pump for?
Discussion in 'First Time & New Camper Owners' started by tfalter, Jul 21, 2011.
  1. tfalter
    tfalter I MUST work, so I CAN play
    160
    Jul 16, 2011
    OK, kind of stupid subject but I have an honest question.
    First off I am currently closing the deal on a 2007 Fleetwood Niagara ... Still smells new... were excited. I was a little worried when I started measuring the garage, those bad boys are a little long.
    Well I know for sure that the water pump is bad, well I say I know for sure, I was told that, first thing will be to check the fuses. But if bad I will replace it with a like kind sure Flo I think.
    Here is my question, can someone explain to me what role the water pump plays when you are hooked to water with a garden hose that pressurizes the system anyway? Is it only for when you are roughing it and carrying fresh water and there is no water to hook to?
    If that is the case and I plan mostly trips local for a while till comfortable, do I have to fix it right away?
    All the sites I will be in through this fall will have water and electric.... you input muchly appreciated...
  2. silvermickey2002
    4,648
    454
    Sep 11, 2008
    Morris County, NJ
    If you are dry camping/boondocking you will need the water pump. But it sounds like you will be using hookups for awhile to get used to things [A]
    The only time we use the water pump is when winterizing and dewinterizing. We do not use the fresh water tank when we do dry camp.
  3. Raycfe
    15,234
    1,449
    City water pressure will push the water thru your faucets, showers, etc, no pump is needed.
  4. cruising usa
    cruising usa New Member
    508
    Aug 19, 2006
    Congrats on your soon to be NTUPUP. Welcome to the portal from the Finger Lakes Region of New York State.
    Use the pump not working as bargaining chip during negotiations. If a fuse is not blown and the pump switch is not turned off measure the voltage at the pump connectors before replacing the pump.
    Remember to purchase a water pressure regulator to use when connected to the city water as the CG water pressure my be high.
    Good Luck and
    Happy Camping
    Ken
  5. tfalter
    160
    Jul 16, 2011
    Thanks a bunch, I did not want to find out on the maiden voiage that it had to be there...
    I sure understand about the bargining ship and thanks for the advive on the water pressure regulator...
    One more thing to add to the list...
  6. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    "...I did not want to find out on the maiden voyage that it had to be there..."
    Don't take it out and leave it out!
    If you do, you need to cap or plug that line securely.
    The pump has a check valve built into it.
  7. tfalter
    160
    Jul 16, 2011
    No problem and thanks... I figure I will just use the camper for a while and hook up to water, then replace the pump in the fall when I have more time and a little more money... these campers aren't cheep...
  8. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    Boy, you got that right. Like a boat, they can just suck up the $$. BUT they're worth every penny. The Niagara's a very nice unit and it is a beast compared to other PUPs. But you get a self-contained PUP that has all the comforts of home-toilet/shower, decent size frig, plenty of storage, microwave, 2 king size beds, etc.
    I'm sure you'll enjoy it.
  9. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    Not only are the campers not cheap...neither are the pumps!
  10. FC
    FC Central Florida
    786
    Apr 2, 2007
    Apopka, Fl
    It's for when you have no hook ups.
