What is this used for?
Discussion in 'Mystery Parts' started by teksavy, Oct 18, 2021.
  1. teksavy
    teksavy New Member
    Sep 4, 2021
    What is the access hatch used for? It looks like it provides access to the connections for the shower. There is no lock on the door. It is just to access the plumbing connections, or is it used for something else?
    Any tips are appreciated.
  2. Tarkus
    Tarkus Member
    82
    60
    Aug 15, 2021
    Wyoming
    Looks like an access door to service plumbing if needed.
  3. Sjm9911
    10,790
    8,170
    Hard to tell without more info on the camper, year make model. And pictures of both sides, door closed and open. If i were a betting man i would say it was for an outside shower that was removed, or a hatch added to cover a repair.
    friartuck and Snow like this.
  4. Snow
    11,817
    2,394
    Both those are possibilities, I just noticed that the edge of the inside panel isn't trimmed out like it would be if this panel was factory..
  5. Sneezer
    2,856
    1,691
    I think you said earlier you had a Rockwood 2506G. I believe they had an external shower on the slideout side, just above where the power cord was. If it is in that location I suspect the PO removed it for some reason. The factory door had a keyed lock as well - having a velcro secured door like that would not be a factory install.
    Rogerbid, Sjm9911 and Snow like this.
  6. brettstoner
    brettstoner Active Member
    100
    107
    Jun 17, 2014
    Toledo, OH
    My guess is either an outdoor shower was removed there or it provides access to winterize the plumbing. I.e. disconnect and drain lines????
  7. teksavy
    teksavy New Member
    Sep 4, 2021
    Thanks for your guesses everyone. The outdoor shower is towards the front of the unit and works well. I think this is just an access hole for the shower plumbing. Weird thing it isn't lockable, etc.
