What just happened with my trailer lights?
Discussion in 'Road Safety Systems' started by RevDocJones, May 27, 2020.
  1. RevDocJones
    RevDocJones New Member
    Jul 9, 2018
    Pup: 93 Jayco Jay Series
    Former TV: 2010 Ford Escape (factory equipped tow package)
    New TV: 2016 Ford Escape (factory equipped tow package)
    Both TVs have 4 wire plug. All lights work normally on the 2010, but that vehicle has gone to the resting place of retired vehicles. Plug the Pup into the 2016 and now when I hit the brakes all the parking lights come on, and when the parking lights are on the brake lights are dim.
    As a test I plugged the Pup in to my father-in-law's truck and everything works as normal.
    Any ideas?
  2. the-one1
    the-one1 Member
    55
    40
    Apr 6, 2016
    The common denominator is the 2016. You can buy a little tester for the 4wire plug that will tell you the issue.
  3. Snow
    10,667
    1,407
    Try hitching up the trailer and new vehicle as normal and connect a booster cable to a rust free point on the trailer tongue and the other end to a clean spot on the tow vehicle, could be a ground problem between the trailer and vehicle.
  4. Anthony Hitchings
    1,026
    448
    Mar 2, 2019
    Sounds like you are probably missing a true ground wire path from TV to PUP via your electrical connector - based on a similar experience.
    A chassis ground path though the hitch is not OK
  5. RevDocJones
    Jul 9, 2018
    Tracked it down - it was the converter box in the wiring kit that was previously installed. Easy fix. Thanks everyone.
