What Kind of Jack to get? 2280esp
Discussion in 'First Time & New Camper Owners' started by RunaRoo, May 19, 2019.
  1. RunaRoo
    RunaRoo New Member
    Mar 23, 2019
    Abbotsford, BC Canada
    Hello, its hard to find out what kind of Jack I need to change a tire on my rockwood 2280esp tent trailer.
    No info in the info packages. You think this would be a Big necessary info to give new owners?
    My truck jack is too small. Anyone know?
  2. Anthony Hitchings
    1,235
    573
    Mar 2, 2019
    IF at all possible, place jack under axle, not under the trailer. (loosen lug nuts a small amount before jacking) Any scissor jack should work. But be sure to chock the other trailer wheel and the front "jack-wheel combo" . Better option is to have front of trailer on your TV hitch ball to stop unwanted large movements. I notice that the ESP trailer sits up pretty high, all the more reason to jack the axle and not the chassis (purely IMO).
  3. Sjm9911
    6,928
    4,312
    With all things emergency related, you will need extra wood to use as cribbing. This is for leveling the pup as well as emergeny tire replacement. I have 2 bottle jacks and an assortment of wood so i can adjust to most terrains. You will not always be on level ground with a blow out.
    kcsa75 likes this.
  4. hometownhiker
    hometownhiker Active Member
    456
    69
    Oct 17, 2009
    Franklin, NC
    I use a bottle jack (2 ton), it works fine.
  5. RunaRoo
    RunaRoo New Member
    Mar 23, 2019
    ya the esp tent trailer is a lot higher than the run of the mill tent trailer. thats the issue. using blocks is a great tip, thanks
  6. generok
    generok Well-Known Member
    2,782
    1,073
    Feb 7, 2013
    Anchorage, AK
    kcsa75 likes this.
