What kind of winch is this?
Discussion in 'Lift Systems' started by TSQ, Sep 28, 2021.
  1. TSQ
    TSQ Active Member
    103
    49
    Mar 28, 2021
    Niagara Region, ON
    IMG_20210928_165238920.jpg IMG_20210928_165318395.jpg IMG_20210928_165345814.jpg
    Had the cover off today to clean & lube but couldn't see anything stamped on it. The sticker is blank. Was just thinking about it because I see a lot of threads about adapters to use a drill but on this one you just use a 3/4" socket on the smaller gear.
    I googled around but couldn't find anything smiliar.
    It may not be original - the up/down direction sticker is not on the same side of the frame as the crank.
    I really need to do some rust cleanup under the winch cover.
    The winch works great, just curious.
  2. Annunzi
    Annunzi Active Member
    180
    153
    Jun 14, 2019
    Vancouver Island, British Columbia
    I believe that's a Goshen winch, probably the 1200, as our 2014 Clipper used the Goshen liftt system.
