what thickness plywood is on your bed?
Discussion in 'Slide-Outs / Bunkends' started by Rideswithchrist, Nov 1, 2017.
Tags:
  1. Rideswithchrist
    Rideswithchrist Member
    139
    24
    Jan 18, 2016
    Buda, TX
    our bed is 1/2"
    We took out the sagging rotted OSB and replaced it with plywood but it does not feel as strong. I am not sure why, maybe because we are not fully buttoned back up yet.
    How thick is your bed? Will 1/2" plywood hold two adults (under 400 lbs total)
  2. lquinn1
    lquinn1 Member
    70
    19
    Aug 17, 2017
    Champaign, IL
    I think mine is 3/4" but not sure if it is original or the PO did it.
  3. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    3/4 sure would be better! I think we may lap another 1/4" over it
  4. Halford
    Halford Well-Known Member
    3,557
    557
    Sep 28, 2011
    Santa Clarita, California
    with good wood glue in between. add brace underneath.
    Rideswithchrist likes this.
  5. f5moab
    1,423
    467
    May 7, 2013
    Somewhere in Idaho
    I'm not sure, but whatever it is, it has held me (200 lbs) and another approx 240 pounds of dogs over the years with no problem.:D
  6. Fless
    Fless Active Member
    939
    191
    Aug 14, 2012
    Colorado
    Unless it's cabinet-grade plywood, I'd rather use OSB. The plywood they sell these days is crap, unless you spend some $$. Don't buy the cheap stuff.
    crackerJack likes this.
  7. nineoaks2004
    7,073
    2,920
    Graceville, Florida
    3/4 would be a best bet at least on most units, OSB is (as stated) also a good choice, but needs to be sealed, in fact I would seal any wood used top and bottom.
  8. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    Well, our Lowes does not carry OSB in 1/2" (15/32) so we had to go with Plywood. From what we read OSB turns to mush when it gets wet and humidity alone will cause it to sag sooner.
  9. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    Original was 1/2". We wanted to go 3/4" and router the edges but we do not have a router so that limited our plans a bit.
  10. tombiasi
    5,204
    897
    OSB won't turn to mush, particle board will.
  11. Fless
    Fless Active Member
    939
    191
    Aug 14, 2012
    Colorado
    You can also seal your wood with SPAR Urethane (not Polyurethane). It allows the wood to breathe and is waterproof -- to a point.
  12. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    The chipboard/OSB that was on it was pretty much mushy expanded crumbles where it had gotten wet-plus it had a horrid sag, which makes me wonder why the newer builds use plywood...BUT the 1/2" plywood Lowes had was not very good.
    For now we are going to lap 1/4 plywood" over the 1/2" we have and for the other side...we will use 3/4" and find a router to get it to fit.
  13. tombiasi
    5,204
    897
    Must have been a severe case. It takes prolonged wetness for that to happen, unless they are selling really crap wood lately.
  14. Halford
    3,557
    557
    Sep 28, 2011
    yea my previous popup had rotten OSB board in the cargo storage area. Caused by prolonged wetness in same area. Won't hurt if it got wet once but constant wetness is the problem with OSB. Plywood gets ruined in short time... much shorter than OSB board.
  15. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    1992... so 26 year of whoknowswhat :) PLUS it was from Michigan so I am guessing snow/humidity took a tool, plus maybe leaky spots.
    We sandwiched another 1/4" on top and it is heavy and solid. Not sure what we will do on the Queen side as it is not as long so may be ok with a nice 1/2" Plywood-? Oddly, the 1/4" was stronger and nicer than the 1/2" from a different store so I guess we got C grade the first time.
