What to use to fix a hole in my Fleetwood Filon roof???
Discussion in 'Roof/Floor Repair & Maintenance' started by Fasttimes7, Dec 20, 2016.
  1. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    We had a disastrous weekend trip last weekend. I've had this Fleetwood camper about going on about 2 years or so and my biggest concern has always that the roof would get damaged, cracked, cause leaks. I'm pretty much on top of things, and keep her in good condition. Careful with what I do and mindful of how to really take care of it.
    But sure enough last weekend while camping in a FL State park a gust of wind in the middle of the night picked up my awning and swung it over the camper coming crashing down on the roof. Scared the heck out of myself and the Mrs. The awning was a mess, the aluminum poles twisted and broke out of it. That I can deal with, fix or replace. But I couldn't see the roof and I prayed no issues were going to be found when we took the trailer down. Unfortunately when I lowered that roof sure enough there was a hole punched in the Filon roof, which is like a fiberglass/gelcoat skin.
    The hole is about the size of a 50 cent piece. Upset is an understatement, as I baby this thing since I know they are no longer made and parts are hard to come by. I'm looking for what is the best product to patch this hole up and get it looking as close to the tone and color of the original roof which is an off-white color.
    I do not want to put any Eternabond tape, more looking to patch and match color. I've been looking at fiberglass repair kits as an option but I'm wondering if there is anything better than that for this fix? Any help would be appreciated.
    -Thanks
  2. 92coleman
    92coleman New Member
    131
    Oct 8, 2015
    Perhaps one of the many JB Weld products out there?
  3. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,705
    May 8, 2011
    Florida by way of WV and MD
    Do a search for "filon roof" or "filon roof repair" and you'll come up tons of info.
  4. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Eternabond
  5. Hawkester
    Hawkester Hawkesnest
    1,337
    29
    May 23, 2008
    SE Wisconsin
    Dicor self leveling lap sealant in white.
    Clean and prep area with the manufacturer's recommended product and procedure and then apply the product.
    Once it starts to set up dab it lightly with a paint brush to add texture and it will be hard to notice.
  6. rjhammetter
    rjhammetter Husband, Dad, Engineer & Camper
    254
    95
    Mar 1, 2016
    Wisconsin
    Fasttimes7: I feel your pain. The exact same thing happened to me on our second trip. Learned the lesson not to use awning on blustery days. I bought a 4" wide roll of Eternabond - really expensive stuff - and applied a 6" long piece over the quarter sized hole that was punched. Stuck and sealed like white on rice. That stuff is no joke. The only reason I wouldn't leave it there for the life of the camper is it's annoying to see. I could take it to a fiberglass shop to patch it. The rest of my 50' roll sits in the garage for the next time I need to vacuum seal anything air tight.
  7. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    With resell in mind, Eternabond is not an option. I've got some left over Sikaflex 221 that I used on it to caulk the roof seems and the color was pretty close. Wonder if that could be used to fill in the hole? Stuff dries pretty hard.
  8. SteveP
    1,757
    547
    The Sikaflex should work. I would work in 3 layers. The first to fill the cracks, the second to start leveling the depression and the last to fully level and finish the surface. Be sure to feather out the edges on all layers. Allow curing time between each layer but check the tube to make sure you don't allow it to set up too hard.
    When you recaulk the seams in the future you should check the patch to make sure it's still sealed.
    myride likes this.
  9. terry1419
    terry1419 Active Member
    669
    82
    Mar 6, 2016
    Streator, IL
    I would suggest that prior to making the patch, drill a small hole at the very end of the narrow part of the gouge and if that is a crack at a right angle to the gouge, drill another one at the end of it in order to prevent the cracks from progressing.
    myride likes this.
  10. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    What year is it?
  11. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    Yeah, I'm going to drill out the crack lines I see.
    Year is 2007 Fleetwood Williams-burg model.
  12. TheEscoMos
    TheEscoMos New Member
    Aug 2, 2016
    We have an aluminum roof (I think) that had an encounter with our garage door opener and got a shallow but long gash. I was very upset about it just like you. My husband used this 2 part epoxy to fix it and it seems like a really solid long term solution: https://www.amazon.com/gp/product/B000AB4A8M/
    Only downside is it is dark grey but I think I can paint it white (if I ever get around to it). He masked off the area with tape and the patch looks nice and neat.
  13. friartuck
    friartuck Well-Known Member
    2,933
    136
    Nov 1, 2007
    Perry, MI
    I too have punched a hole in my Filon roof, but with a bicycle handlebar. I used a fiberglass repair kit. True the color isn't a great match, but I have not had a leak in 4+years. And since it's in the middle of the roof it's not noticeable
  14. Adam H
    Adam H Active Member
    515
    202
    Aug 22, 2015
    Though I don't have any pictures, I had a similar situation punch a hole in my Avalon's roof. I used 2 part epoxy to fill it in and sanded the fill with some 150 grit paper. Scrubbed the entire roof with TSP, then I touched up the area with exterior latex paint (color was sightly off) and coated the entire roof with SealKrete for UV protection. SealKrete also made my sun faded roof look like new again while sealing and protecting it. Still contemplating using a roof coating over the SealKrete but haven't done it yet....
    Adam
  15. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    2007, I'd say whatever it takes to prevent a leak won't affect resale much
  16. Halford
    Halford Well-Known Member
    3,563
    569
    Sep 28, 2011
    Santa Clarita, California
    Good time to put Grizzly seal on whole roof... after the repairs.
    myride likes this.
  17. CarribeanCamper
    CarribeanCamper CarribeanCamper
    129
    Aug 20, 2015
    Marine rec. Ace hardware or any West Marine. For less then $20 for a lifetime and easy to sand down.
    Sent from my LGMS428 using Tapatalk
  18. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    **Update**
    So after reviewing old posts on the subject matter I decided to follow these procedures from CampingFamily1 back in 2008 http://www.popupportal.com/index.php?topic=16154.0. I went to Walmart and in the automotive section and got a 5 min 2 part Epoxy from Permatex. Walmart didn't have the paint mentioned in that post from the past so I had to go to a Pep Boys. There I got the recommended Ford Oxford Touch Up paint, but also saw a can of paint that looked more like the color of my Filon roof, it is Dupli-Color Wimbledon White.
    I drilled out the ends of the four pronged hole to prevent spidering. Then I applied the 2-part epoxy. The packaging said dries clear, but turns yellow in sun. Well, this stuff turned yellow right away. But that wouldn't be an issue since I'd be sanding it and painting.
    I then sanded down the raised "scab" of epoxy with a emery-like drill attachement, and some 600 grit paper. I probably could have done a better job had I been more patient, but it'll do. Cleaned off with a bit of acetone.
    I tested the two paints I bought and went with the Wimbledon White. It seemed more of a match to my Filon roof color, which is off white leaning towards the cream/yellow side. I'm not sure if that is the color it came from the factory or if it was more white and the sun turned it this tone.
    In the end I'm ok with the outcome. The paint color is close, not exact, but good enough for me. I'm not going to put on any clear coat or sealer at this time and will observe how long it handles the weather.
    BelchFire likes this.
  19. JPBar
    JPBar Well-Known Member
    1,873
    583
    Sep 22, 2016
    Texas
    Nice fix, and if you are happy that is all that matters
    daleick likes this.
  20. daleick
    daleick New Member
    Aug 7, 2018
    My 2007 Coleman Utah suffered 16 punch dent/holes due to golf ball and larger size hail this week. Is it worth trying to fix? Will insurance total it? I’ve envr had an insurance claim on my pup trailer in 18 years of owning them. Have loved my Utah, and never had a problem except with the stepper door.
    Any thoughts or suggestions?
