What type of glue to repair rubber gasket seals around door hatches?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Fasttimes7, Sep 20, 2017.
  1. Fasttimes7
    Fasttimes7 Member
    115
    Sep 7, 2014
    The rubber gaskets around the large door lid and side lid of my campers front storage compartment are coming undone. I'm hoping there is some type of glue out there that can be used to put the rounded edged rubber gasket back in place and stay in place.
    Any suggestions?
  2. JPBar
    JPBar Well-Known Member
    1,873
    583
    Sep 22, 2016
    Texas
  3. sleach
    697
    166
    May 17, 2014
    Boulder, Colorado
    I recently had to replace the seals around the two top hatches on the Chalet's front bunker. The tip off they needed replacement was finding water standing in the bucket inside. Seals had dried out, cracked and crumbled.
    Found suitable replacement seal material at McMaster-Carr. The seals are a U-shaped channel that presses on the edge of the molded fiberglass, with a D-shaped bulb to seal against the bottom of the hatch. Loctite Stick and Seal Outdoor Adhesive seems to have worked well to get secure attachment and a seal against water. Application technique was to apply adhesive to 2-3 inches of fiberglass, then force seal into place. Were I to do the job again I would wear an old shirt and vinyl gloves.
  4. neighbormike
    2,814
    2,602
    Oct 6, 2012
    WI
    I agree with JPBar... the 3M weatherstrip adhesive works great for many applications! Comes in yellow or black if it matters.
  5. xxxapache
    3,356
    1,342
    Goop
  6. Fless
    Fless Active Member
    971
    211
    Aug 14, 2012
    Colorado
    The trick that most people miss when using the 3m Super stuff is to use only a little and let it get tacky. Most want to put a lot on and make the contact right away.
    neighbormike likes this.
