What's Hot? What
Discussion in 'Tow Vehicles, Hitch & Towing' started by JayGoCamper, Jul 6, 2019.
  1. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    From reading here, I have learned that it is wise to use an IR thermometer to check the temperature of the tires and wheel hubs during stops along the way. I can do that, but what is the "alert" temperature? And what should I do if I reach it?
  2. tombiasi
    5,434
    1,065
    The answer is complex. Ambient temperature, road temperature, rim temperature all play a part in tire temperature.
    A rule of thumb might be around 125°F. If they are too hot to touch check air pressure and slow down. Check the hub temperature while you are at it.
    generok likes this.
  3. nineoaks2004
    7,462
    3,202
    Dukes, Fl
    I check mine before leaving, then on the road
    I compare the wheel temps.On all wheels If there is a large discrepancy then I have a good idea
    which one /s could be a problem
  4. bheff
    bheff Well-Known Member
    1,044
    527
    Feb 24, 2011
    NW Arkansas
    Same as above. I touch all the hubs everytime I stop. If they are warm, all is good. Hot, then I need to look further into the cause.
  5. Sjm9911
    4,967
    2,624
    I do the same by touch. Mine dont run hot, but they are warm. Not very scientific, but so far so good. Every stop i check them and look over the pup. Additionally when i leave a rest area, i do a walk around in case someone undoes one of my roof buckles. It adds time to the drive , but less if i can prevent a worse problem.
    HappyTraveler, Raycfe and bheff like this.
  6. hayyward
    hayyward Active Member
    257
    126
    Sep 16, 2006
    Packerland
    Good to get out and stretch your legs. At our halfway stop, I'll circle the PUP and TV a few times to get the blood moving.
    HappyTraveler likes this.
  7. BikeNFish
    BikeNFish Well-Known Member
    3,031
    1,926
    Apr 24, 2017
    Maplewood, MN
    Same. Touch hubs and tires at EVERY stop. If they are beyond warm, you have a problem.
  8. JayGoCamper
    JayGoCamper Member
    31
    26
    Jun 18, 2019
    Thanks, all. It's good to know that warm is okay. I will definitely touch the hubs, and do the walk around to check latches, lights and safety chains. I had my tow bar put on today, so tomorrow I get to do driveway practice, pulling forward and backing up. I'm so freakin' excited!
