What's wrong with this picture?
Discussion in 'Tow Vehicles, Hitch & Towing' started by flash82, Jun 25, 2012.
  1. flash82
    flash82 Member
    455
    Jun 24, 2008
    Northern KY
    Going home from work last week I saw this:
    I call it the 'Ghost pup up"
    This is what is was: (it was worse than the pic shows)
  2. Sharon
    Sharon Dover, FL
    1,748
    Oct 28, 2008
    Dover,FL
    Ha! Reminded me of that commercial. "Hey, That looks like our Pup" As it passes the car that was pulling it.
    Sharon
  3. Lauren5280
    Lauren5280 Member
    485
    Feb 27, 2011
    Peachtree City, GA
    LOL Too funny :)
  4. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    worse how?
    it is funny to look at though...lol
  5. PaulinBawlmer
    PaulinBawlmer I'm a traveling man ஃ
    169
    Feb 20, 2012
    Holy cow! Were the (ahem) TV's front tires even touching the road? I can picture it hopping down the road like a lowrider...
  6. CitaPita
    CitaPita New Member
    37
    May 31, 2012
    Whoa! They are braver than I am, that's for sure. Looks like a pretty big PUP for that car, but I guess it's hard to know what mods they've made.
    The first picture is hilarious!
  7. rabird
    6,718
    307
    TX
    It's incriminating, it shows the driver of a vehicle taking pictures while driving. [;)]
  8. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    this post wins [:D] [:D]
  9. warwgn3
    warwgn3 Car Shows are 2nd only to Camping!
    246
    Feb 21, 2010
    That 1991-1996 Chevrolet Caprice has a full perimeter frame and has a towing limit of 3500 lbs, so it should be fine towing that camper. It just needs a WDH to compensate for the extra weight. on the rear axle and coil springs.
    I've towed a trailer like that with my car before as well. My car is a uni-body frame and has a 2000 lb tow limit with a bumper hitch so a WDH is not an option for me.
    That being said... My car has the advantage of being equipped with automatic load leveling air ride suspension. so I'm not worried about towing such a large camper.
    It has 3 sensors (2 front, 1 rear) and adjusts the ride height to a preset level. The sensors tell the computer to open the air valves so the compressor can fill the air springs to raise the car or let the air out to lower the car, depending on how much weight is in the car.
    Before leveling
    After leveling
    Another advantage to the air ride is that if I need to do something under the car, (hanging a tailpipe with a wire hanger), and I don't want to jack the car up for safety reasons, (parked on an incline with no parking brakes).
    I can "trick" the air suspension by turning on the ignition, have people stand on the bumpers, and listen for the compressor to stop pumping air into the springs, and turning switch off in the trunk before everyone gets off the car.
    Doing this also comes in handy in instances where a higher ground clearance is desired, (going on an off road path), and I'm worried about damaging the underside of the car.
  10. dschlosser
    dschlosser Active Member
    961
    Jan 29, 2008
    East Patchogue, NY
    If I remember correctly it had a 5000lb rating when equipped with the 5.7L V8 and the towing package. Thoes early 90's full size GMs were tanks.
  11. warwgn3
    246
    Feb 21, 2010
    That's the Station wagon you're reffering to. This one is only a sedan.
    Also on closer look, the car in the pic is actually a Buick Roadmaster, not a Chevy Caprice. I stand corrected.
  12. PaulinBawlmer
    169
    Feb 20, 2012
    That's pretty slick!
  13. BelchFire
    1,688
    403
    Mar 29, 2012
    SE Georgia
    I just wanna know how fast that semi in the second picture was bookin!
  14. flash82
    flash82 Member
    455
    Jun 24, 2008
    Northern KY
    After I put down the camera...I knew someone was going to mention that...and I passed, I noticed the back tire was up in the wheel well so far I think tread was was coming off.
  15. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    ok, I understand better now...
  16. blondedriver
    blondedriver Member
    314
    Sep 2, 2008
    I have a 94 Grand Marquis and the car will pull 5 grand 10 with the distrabution hitch ,, and really depends on that GM on the rear axel ,, but no diffrent than pullling it with a Mini van!!
  17. warwgn3
    246
    Feb 21, 2010
    Will your Grand Marquis be able to stop that amount of weight?
    My fox body 90 Lincoln Mark VII could probably pull about the same as the larger panther body grand marquis, if I installed a larger hitch, but the difference in frame construction and brakes makes me not want to go over the 2,000 lb towing limits.
    My little trailer is pushing 1,000 lbs fully loaded and I can definitely feel the extra weight when slowing down and stopping.
  18. bigdad
    bigdad Active Member
    3,577
    Mar 5, 2007
    Springfield Kentucky
    In the pic it need air bags in the coil springs and thin it would be all right i have air bags in my 2005 Grand Marquis and it help big time
  19. warwgn3
    246
    Feb 21, 2010
    Do you have airbags on all 4, or just on the rear? My Mark VII has bags on all 4, and not only does it help with towing as you say, but it's one heck of a smooth ride.
  20. larson6
    larson6 New Member
    Jun 20, 2012
    What really gets me about this is the mirrors that couldn't see past the pup awning. I don't know why, but it irritates me to no end to see someone towing (usually a TT) with nothing more than 4" non convex mirrors. There is no possible way they can see anything other than what they're pulling, and although around here we only have 1 multi lane hiway it still drives me crazy.
