What's your favorite battery meter?
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by tscia23, Nov 2, 2016.
  1. PopUpSteve
    PopUpSteve Administrator
    19,570
    2,191
    Dec 22, 2002
    Malvern, PA
    I'm not sure but I hope to test it this weekend. I'll let you know.
    It does say that the blue backlight can be turned on/off manually. I guess that's what the button on the right is for.
  2. tscia23
    tscia23 New Member
    Oct 27, 2016
    How'd it go?
  3. tenttrailer
    3,482
    486
    Jul 18, 2013
    Thornville, OH
    popupsteve would love to hear your feedback on that new meter.
  4. PopUpSteve
    19,570
    2,191
    Dec 22, 2002
    Malvern, PA
    I couldn't find it when I got to the CG. That and a few other things have just up and vanished. As soon as I order a new one I'm sure I'll find this one.
    On the good side, my dual battery mod worked perfectly. My heater was running the whole time (42 hours). But not knowing the battery status was nerve racking. It's like driving your vehicle with a broken gas gauge. So getting this meter operational is on the top of my to do list for the camper.
  5. tenttrailer
    3,482
    486
    Jul 18, 2013
    Thornville, OH
    That sounds like the 2nd battery did the trick. Were you able to check the voltage?
    We went the other way and got an 80w solar panel. Seems to be working well, If we get a full day sun every 3 days, or some sun 2 out of 3 days we seem to never drop below 12.2v when heating. But we only run the furnace for about 10 hours a day.
  6. nineoaks2004
    8,214
    3,677
    Dukes, Fl
    I have several Multi-meters but my favorite ones are the give aways at Harbor Freight, they are free and if they go bad, I throw it away and get another.
    Other than that I do not worry about it.
  7. JimmyM
    JimmyM Well-Known Member
    2,941
    921
    Jun 5, 2014
    Franklin, MA
    I like the AH accumulator types. Tri-metric is this type.
    I've used the Link10 (predecessor to the LinkLite from Xantrex) in my Jayco pup ($197 on Amazon).
    But for my new Starcraft hybrid, I'll be using the BMV-700 from Victron ($160 on Amazon):
    Both probably overkill, but I like overkill.
    justwork likes this.
  8. PopUpSteve
    19,570
    2,191
    Dec 22, 2002
    Malvern, PA
    Yup, that second battery definitely did the trick. I could not find the meter so I had to order another one.
  9. tscia23
    tscia23 New Member
    Oct 27, 2016
    THAT looks great! More data than I need AND bluetooth to the phone (with dongle). I know what I'm asking for xmas now. [:D]
    I too like overkill, haha.
  10. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
    Like Wrenchgear...didn't need anything to involved. Let me see what my golf cart batteries are doing, good nuff for camping. Reach in the door, press the switch, easy breezy. I also have a budget digital multi-meter in my camper tool box in case I have to chase a voltage/ground problem when camping.
  11. Twyner
    Twyner New Member
    Feb 9, 2012
    I went with just a simple $3 meter and toggle switch. Does the job for me.
  12. tenttrailer
    3,482
    486
    Jul 18, 2013
    Thornville, OH
    That's the one I have. But I put it on the battery case so I can also check the voltage when top is down.
  13. xvz12
    xvz12 Well-Known Member
    891
    539
    Apr 6, 2017
    ID
    I installed one of these on the galley cabinet of our PUP, it was like 10 bucks from the bay of evil...sorry, I don't have any pics of it installed yet.
    EdZilla likes this.
  14. justwork
    justwork Active Member
    153
    53
    Mar 27, 2017
    Thanks for this... Just pulled the trigger. Watched some videos on youtube and feel like this is a great unit. I didn't order the bluetooth dongle but maybe down the line.
  15. JimmyM
    2,941
    921
    Jun 5, 2014
    Franklin, MA
    I got mine a few weeks ago. I'll be installing it this summer at some point. A lot of my weekends are already spoken for.
  16. Ian Worthington
    Ian Worthington New Member
    26
    May 21, 2017
    Raleigh, NC
    I am new to the pop up world, as I just bought my first one a couple of weeks ago. I DEFINITELY want to install a battery/ DC Amp usage monitor, as well. However, my ignorance of how to do such things leaves me without a way to understand how to connect the wiring in my pop up (1999 Coleman Niagara) to a unit like Wrenchgear, HiFiDave, and Twyner are using. Is there a manual/ guide on how to do so?
  17. JimmyM
    2,941
    921
    Jun 5, 2014
    Franklin, MA
    Ian,
    Those meters are the simplest to connect. There's just a positive wire and a negative one. Connect them to the camper's 12V electrical system + to + - to - and you're all set. Some choose to put a switch in to read the voltage only when the button is pushed.
    It only takes a tiny amount of current to drive one of these, so any push button will work.
    Ian Worthington likes this.
  18. JimmyM
    2,941
    921
    Jun 5, 2014
    Franklin, MA
    I've got my BMV-700 installed. It works great. I did get the bluetooth dongle. I've tied the alarm contact into my alarm panel. So at a predetermined state-of-charge the contact closes and I get a warning.
  19. Mogimus
    Mogimus Active Member
    486
    82
    Apr 29, 2015
    Rancho Cucamonga, CA
    I just pulled the trigger on the BMV-700 with dongle. I've seen some videos and reviews that talk about setting up the right parameters. Just wondering, how involved was your setup? Did you have to go through and figure out you configuration or does it work with the default parameters? Does solar though a monkey wrench in the mix?
  20. JimmyM
    2,941
    921
    Jun 5, 2014
    Franklin, MA
    I adjusted the battery bank size to match my dual GC2s. That's it.
    Solar doesn't throw any monkey wrenches. Solar just provides charging current and the meter measures net current in or out of the battery. Easy peasy.
