Wheel hub replacement - 1995 Coleman Cedar
Discussion in 'Tires / Brakes / Bearings / Axles' started by Jonico, Sep 15, 2021.
  1. Jonico
    Jonico New Member
    21
    Aug 31, 2021
    Upstate NY
    I need to replace the wheel hubs and bearings on my Coleman Cedar and I ordered this kit. It seems to be the right one, but my measurements seem slightly different than the dimensions they list. Does anyone have experience with this and know if this kit will in fact do the trick? Thanks...Jon
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    What is your spindle diameter? Measure with calipers.
  3. Jonico
    Jonico New Member
    21
    Aug 31, 2021
    Upstate NY
    1 inch
  4. WrkrBee
    6,538
    3,448
    It will work. Just use the right set of bearings (1 inch ID) from the kit. Make sure you check the wheel bolt pattern before installing the hub, in case that's an issue.
    Jonico likes this.
