Where to buy new center trim piece for the roof.
Discussion in 'Roof/Floor Repair & Maintenance' started by GaryRothenberger, Apr 29, 2012.
  1. GaryRothenberger
    GaryRothenberger New Member
    Apr 29, 2012
    Hello everyone!
    I am needing to reseal the center seam on our pop up. I want to remove the old trim, clean it all up then reseal with eternabond tape and a new trim piece.
    I see where to buy the vinyl insert, but not the actual trim.
    Thanks for the help.
  2. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    Welcome to the Portal, Gary. It would be helpful if you give the yr., make, and model of your PUP. Might want to put it in your signature so it's always there for members. Things like trim, gaskets, etc. can be PUP specific.
  3. sg1215
    sg1215 my God, my Country, my Family, my Friends, myself
    151
    Jan 13, 2010
    Hi Gary:
    I just want to comment on the vinyl insert for your trim. I rebuilt my roof a while back and put the vinyl insert in the trim. I got it at a trailer repair store. It was hard to work with and get in the track. It also blew out on my next camping trip. This time I went to the store and got a piece that was soft like rubber. It went in the track real easy using a putty knife. Good luck.
  4. Sharon
    Sharon Dover, FL
    1,748
    Oct 28, 2008
    Dover,FL
    Camping world caries a lot of the center vinyl trim. I got mine there. They have different widths so make sure you take a piece with you to compare.
    Sharon
  5. smoreking
    smoreking Member
    400
    Sep 15, 2009
    Small Town, Middle TN
    Hey Gary, If you really want to replace the aluminum trim you may need to get it from the dealer. I have had luck with pulling slowly and prying the butyl tape loose with a putty knife, scraping it clean, and re-using the old trim. Just don't twist or pull it sideways when removing it and it will bend right back into place when you put it back on.
  6. Raycfe
    14,743
    1,230
    [:D] Welcome from Connecticut, happy camping, enjoy. [CP] the vinyl insert is a common part, just measure the old ones width. Install it when warm and the very edge can be folded back on itself to make a nice finished end.
  7. GaryRothenberger
    Apr 29, 2012
    Thanks, I appreciate the feedback.
    Gary
