Where to spray the waterproofing spray
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by crisnrich, Jul 1, 2009.
  1. crisnrich
    crisnrich New Member
    83
    Mar 9, 2009
    Ok, I know this will sound dumb, but we have the vinyl backed canvas. Do we spray the Sno-Seal on the vinyl side, or the canvas (inside) or inside AND outside? We need to seal up the bunk end seams. Thanks
  2. dupreet
    dupreet New Member
    2,184
    Jul 5, 2007
    High Point, North Carolina
    I would reserve the Sno-Seal for the seams.....on the outside. You will need a spray waterproofing like 303 or Scotchguard for Outdoor Fabrics to apply to the exterior (vinyl) surface.
  3. crisnrich
    83
    Mar 9, 2009
    OK, so I don't spray any sno-seal on the inside which is the canvas side? Just spray over the seam stitching on the outside?
    As far as we can tell, the only leaking is coming thru the seams. The vinyl walls seem to be holding the water out, just coming in thru the stitching where the bunk support pushes against the canvas.
  4. dupreet
    dupreet New Member
    2,184
    Jul 5, 2007
    If your seams are the only problem, then yes, you will apply it to them....outside would be most effective. FWIW, Sno-Seal is a beeswax compound that is that is applied by hand....its not a spray. You will find it in a small pint-sized paint can.
    Good Luck!
  5. crisnrich
    83
    Mar 9, 2009
    Oh...thanks for the clarification. I have the orange capped spray from Walmart...it says it's made by Sno-Seal. thought it was the same thing. Boy do I still have a lot to learn! LOL [RTM] Thanks for the help! :)
  6. krh1130
    krh1130 New Member
    83
    Mar 20, 2009
    Michigan
    Thanks for asking this question....I was wondering the same thing!!! [:D]
  7. Daduv3Boys
    Daduv3Boys American by birth, Southern by the Grace of God!
    297
    May 25, 2009
    Harvest, AL
    Thanks Cris. I too was wondering if we did it right. Now we all know!
  8. NismoGriff
    NismoGriff New Member
    60
    Jan 9, 2009
    Lorain Ohio
    I too was wondering about this. I doesn't appear to have any leaks after it sat open in my driveway through many rains and it rained on our first trip out. However, I was wondering how often the sealing is done? Every year? Only if it leaks? Usage dependant?
