who tows with a nissan frontier
Discussion in 'Tow Vehicles, Hitch & Towing' started by daveB, Apr 7, 2016.
  1. daveB
    daveB Member
    62
    Mar 9, 2014
    N/W pa
    I have a 2011 nissan frontier crew cab,long bed, 4.0 v6. what do you tow with yours and do you feel safe towing with it.
  2. keithert
    keithert Member
    145
    Nov 11, 2009
    I have a 16 Tacoma which is quite similar. I pulled my Coleman Niagara with it and it did well. I had a Frontier before the Tacoma and felt the Frontier was a bit more powerful. You will need to add a brake controller to the Frontier if your camper has brakes.
  3. WingShot
    WingShot New Member
    632
    May 14, 2014
    I have a similar 2012 Frontier V6 4.0, but with the short bed. Max tow capacity of 6000#'s.
    Tow one of the heavier small PU's, a Coleman Evolution1, GVWR of 3500#'s. And we are at that weight.
    Pull it into the Rocky Mountains on a regular basis with no issues. Definitely need the trailer breaks working for coming down the hills, but they do a good job. We're boondockers, so haul in a full tank of water, 2 - 20# propane tanks, group 27 battery, and a smaller generator. Don't think I would feel very comfortable with much more weight pushing me around.
  4. ericgregoire
    ericgregoire Member
    140
    Jul 10, 2012
    Ottawa - Canada
    I'm also towing with a 2011 Frontier crew cab, long bed. I love it. Better mpg then the RAV4 I had. No need for a WD kit in my case. Installing the tow kit was a breeze , hitch, brake controller (Tekonsha P2), relays, can been done in 1hour in your laneway. I'm towing a 2006 Jayco 1006, no sweat.
    Envoyé de mon Nexus 9 en utilisant Tapatalk
  5. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    Work is all they know...
    That's probably about a 2200# loaded camper, and maybe 300 in the bed. Barely know it's there.
  6. daveB
    daveB Member
    62
    Mar 9, 2014
    N/W pa
    looking at a 20ft tt with a gvrw of 4500lbs and is curious if anyone pulled that weight.have the brake controller already.
  7. R00
    R00 Active Member
    1,286
    17
    Aug 10, 2014
    That's a fat trailer for a Frontier.
    It's rated to pull it, but you're going to be taking your time getting there, and it won't be a pleasant tow. I think the biggest issue you'd have is the frontal area on the trailer acting as a huge wall, and being 20' long, you might end up with a tail wagging the dog situation.
    I would look into a full size truck or a smaller trailer.
  8. daveB
    daveB Member
    62
    Mar 9, 2014
    N/W pa
    owners manual restricts frontage to 60sq ft max and I have looking at 7ft wide campers.wife doesn't like crawling on the floor or opening up to fill fridge.doesn't bother me though.happy wife,happy life
  9. utah steve
    utah steve New Member
    74
    Apr 17, 2016
    I tow a Coleman Utah, with 2012 Frontier,crew cab. Hardly know it's back there. I need to add sway control, because it sways at 65.
    Sent from my SM-T330NU using Tapatalk
  10. sdpadsfan
    sdpadsfan New Member
    185
    Jun 23, 2015
    I've not towed with a Frontier, but we tow our Roo 19 GVWR 4750 with a 2006 Tacoma. It's not fast and the mileage really takes a hit, but it handles much better than I expected. In fact, it tows better than out Jayco 1209sc did. A WDH and sway bars really make a difference.
