Why do my van tires sound funny after last camping trip?
Discussion in 'Tires / Brakes / Bearings / Axles' started by CamperChrissy, Aug 23, 2017.
  1. CamperChrissy
    CamperChrissy Well-Known Member
    656
    365
    Nov 25, 2016
    Chicago suburbs
    So after we returned from our last camping trip, I've noticed the tires on my van are making more noise than they used to. Like a slightly louder, slightly more high-pitched sound than before. Gets higher pitched as I drive faster and lower pitched as I slow down. I checked tire pressure and it's fine. We were towing with the van level, thanks to our new airbags installed in the springs. Any ideas why tires would sound weird now? Did they somehow get worn down unevenly from towing?
  2. 1380ken
    1380ken Well-Known Member
    2,779
    1,186
    Nov 7, 2013
    Mass
    Could have a slipped belt in the tire.
  3. daschnoz
    daschnoz Active Member
    273
    56
    Feb 9, 2015
    Are you sure it's the tires?
    DW's van was exhibiting the same symptoms that you describe. I thought it was the front wheel bearings. It turned out to be the brakes. She needed new front brake pads. The rotors were also shot so I replaced them as well.
  4. CamperChrissy
    656
    365
    Nov 25, 2016
    Chicago suburbs
    Hmmm, maybe is the brakes. I noticed a month or two ago that they were making the squeak sound that happens when the pads get worn down. Told hubby, but he says they were replaced not long ago and should not be worn down yet. I'll ask him to take a look. Thanks for the tip!
    Hope it's not the belt in the tire. Tires are also pretty new. Ugh!
  5. daschnoz
    273
    56
    Feb 9, 2015
    They put the ticklers on the brake pads for a reason. Don't ignore the squeak.
    arthuruscg likes this.
  6. jmkay1
    7,075
    4,139
    . Just a reminder...when you're towing you go through break pads faster then when your not towing even if your camper has breaks.
  7. Winchested
    Winchested Member
    321
    Jun 19, 2015
    Yep and putting an Extra 6-10 lbs in the rear tires helps too. If the rating on the tire allows for it.
