Why won't my satellite booster work?
Discussion in 'Campsite Electronics' started by Freedom72, Jun 20, 2016.
  1. Freedom72
    Freedom72 Member
    278
    May 19, 2010
    Our new 2017 KZ toy hauler has a satellite antenna on the roof. You dont have to crank it up,its always up. I ran a small piece of coax cable from my led tv to the input on my ceiling marked satellite. I pushed in the button and it lights up red.
    I then made sure my tv was switched to cable on the input.
    But still no channels...What am I missing? Do I have to pay for satellite tv?
    Thanks for any help
  2. Nandy
    Nandy Active Member
    2,255
    22
    Mar 29, 2010
    if in deed is a satellite antenna I would think you will have to pay for the service and have a receiver.
  3. Freedom72
    Freedom72 Member
    278
    May 19, 2010
    Nothings free lol
  4. Snow
    11,812
    2,389
    I agree with Nandy, you'll need a compatible receiver along with a plan from a provider..
    Do you also have a regular tv antenna and booster or just the satellite set up ?
  5. Customer
    Customer Well-Known Member
    2,435
    249
    Jun 5, 2014
    A satellite antenna, seriously? Many toy haulers come with an omni-directional over-the-air antenna which is round.
  6. roybraddy
    roybraddy Well-Known Member
    2,394
    960
    Mar 23, 2016
    King George, Virginia
    Find the paper spec sheet on the SATELITTE antenna in your folder of brochures. Maybe get the model number and post it for us to see...
    I suspect it is one of those VHF-UHF-FM antennas to pick up OTA signals from your surrounding areas... If it is one of those type antennas I also suspect you will really wished you had the standard crank up BATWING antenna for best performance....
    Switch your TV SET MENU to ANTENNA and rescan and you will most likely pickup local NATL BROADCAST OTA digital stations from the local towns...
    Roy Ken
  7. swordfish
    swordfish Well-Known Member
    2,231
    60
    Sep 27, 2010
    If you are within 60 miles of TV stations, this inexpensive antenna can get you tons of cartoons, old movies, CBS news, ION, and WGBH/WorldChannel - totally 21 channels the last time I counted. Not that I watch TV that much. It is part of the fun to overcome obstacles in a camp setting.
  8. Freedom72
    Freedom72 Member
    278
    May 19, 2010
    Brand-Continu.US / Model# CA-1500
    am/fm
    vhf: 47-230mhz
    uhf: 470-770mhz
    power supply DC 12v 150ma
  9. Snow
    11,812
    2,389
    That is a TV antenna not a satillite ...
    As Roy mentioned, set your tv signal input to "Air" (or antenna, what ever you tv lists) and with the signal booster turned on, have the tv re-scan the channels..
  10. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    Since you've just bought it... what did the salesman tell you it was?
  11. Customer
    2,435
    249
    Jun 5, 2014
    You have an omni-directional over the air antenna. It will NEVER receive satellite signals.
    Here is the manual;
    http://continu.us/content/manuals/CON_CA-2500_Manual.pdf
  12. tombiasi
    6,670
    2,233
    I usually just set up these and can get just about anything I want.
    https://1drv.ms/i/s!AmXqONNmKuFhvFPTl4VuHGpJMh4G
  13. Snow
    11,812
    2,389
    Tried that once but got some foreign planet and couldn't understand a thing they were saying ... [:D]
  14. tombiasi
    6,670
    2,233
    Are you too cheap to pay for the universal translator?
  15. Snow
    11,812
    2,389
    Forgot it at home ... only had the NCC 1701 ...
  16. tombiasi
    6,670
    2,233
    Would be a shame to tie up an enterprise class starship for just a xffrrgghjr game.
  17. Freedom72
    Freedom72 Member
    278
    May 19, 2010
    Ok then can u explain this to me please...
    On outside rear of camper their is a decal says cable in with a female cable connector. Inside the camper on the ceiling their are 2 other female cable connectors.
    1 says cable the other says satellite with a booster button,when pushed in it lights up red
    Thanks for any info...
  18. Snow
    11,812
    2,389
    Well the one is self explanatory , connect the outside connection to the campground cable feed (yes some of the "resort" places offer cable) and connect the inside cable connection to your tv and set tv source selection to cable.
    The other one.. by all of your description it sounds like a tv antenna.. Didn't you get any paper work (manual, brochure etc) for all the accessories in your trailer ?? What did the sales person call it on the walk thru ? Is it possible to post a pic of it ?
    It is possible that the manufacture installed a satellite booster instead of a tv booster ..
  19. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    It's a brand new RV... it almost certainly came with crate of handbooks, which will inform you better than any amount of blind guessing in here
    As we say in the engineering trade, "RTFM"...
  20. tombiasi
    6,670
    2,233
    RTFMWAEF
