Wide or Skinny tires on the PUP?
Discussion in 'Taking Your Camper Off Road' started by ccarley, Feb 5, 2015.
  1. ccarley
    ccarley Member
    124
    Sep 23, 2014
    Pretty straightforward question I have here, and it's been a difficult thing to search for. I'm going to be ordering a set of new wheels and tires for my little Starcraft, but which will be better? Tall & skinny, or a little shorter & wider? I know that taller will be better for long trips down the hiway, but when we hit the dirt, would wider be better?
    Tall & Skinny:
    http://www.etrailer.com/Tires-and-Wheels/Kenda/AM30620.html
    Shorter but wider:
    http://www.etrailer.com/Tires-and-Wheels/Kenda/AM3H290.html
    Thanks,
    Clay
  2. Halford
    Halford Well-Known Member
    3,563
    569
    Sep 28, 2011
    Santa Clarita, California
    yea wider is better if you have to tow it out of your yard or campsite that just got muddy. Skinny tires scares me.
  3. ccarley
    ccarley Member
    124
    Sep 23, 2014
    The skinny tires do look kind of scary too, but the tires I have now really look scary!
    They are so tiny they feel like toys. In any case, I'm leaning more towards wider now; I expect to be taking this unit on some unimproved dirt roads, and may possibly be muddy. Or, there is the potential for sandy beach type areas as well...
    Not sure how long etrailer will have free shipping (is the countdown a gimmick to get you to buy now?), but 2 mounted tires for just over $100 seems like a decent deal.
    Thanks,
    Clay
  4. Halford
    3,563
    569
    Sep 28, 2011
    It looks great on the right sized camper...
  5. mickaqua
    mickaqua Member
    677
    Aug 3, 2012
    Call ET for some good advice. :)
  6. Kawartha-Camper
    Kawartha-Camper New Member
    749
    Aug 31, 2013
    Definitely interested in those wider tires now
  7. Raycfe
    17,006
    2,590
    Here is my take ........
    The 480-12" has a diameter of 20.5" and a capacity of 990lbs @90psi
    The 215/60-8 has a diameter of 18.3 and a capacity of 935lbs @50psi
    Don't let the 8" wheel fool you..... the 215/60-8 Tires hold a lot of air, which hold up the trailer.
    Either tire will do the job. The trailer would ride better with the fat tire.
    On my old Jayco I went from a 480-8 to a 480-12 now that was a lot taller tire comb.
  8. ccarley
    ccarley Member
    124
    Sep 23, 2014
    Thanks for the info. It sounds like the wide tires are the way to go, as long as they fit... it looks like they should, and I'm pretty sure I've seen some other Starcraft owners with the same tire/wheel combo around here.
    Thanks!
    Clay
  9. ccarley
    ccarley Member
    124
    Sep 23, 2014
    Wide tires ordered [:D]
    Thanks everyone!
    Clay
  10. ccarley
    ccarley Member
    124
    Sep 23, 2014
    Just to keep everyone up to date, as it was hard for me to find info in the past.
    I received the new wheels & tires yesterday, etrailer.com is pretty cool. I was surprised to find a giant box with the tires in it on my deck when I got home from work! In the past, when I have ordered tires, the shipper has just slapped a label on the tire itself...
    In any case, I went to test fit one of them, and it is a smidge too wide. The rubber hits the trailing arm on my tor-flex axle when the wheel is right at the hub face. No big deal, I ordered some wheel spacers; I figure 1/2 inch extra should be just right.
    The trailer, just for additional info, is a Starcraft Starlite 17. The original wheel/tire combo was a 5.70-8, and the new tires are indeed the 215/60-8.
    The spacers should be here next week, and I'll see how they fit then! Definitely no problem with the height; just the width of these tires. During the test fitting, I did note that they fit inside the wheel well completely right now. After the spacers, well hopefully they won't stick out too much but I didn't measure that yet. Worst case, I suppose I could find some wider flares :)
    Clay
  11. ccarley
    ccarley Member
    124
    Sep 23, 2014
    I finally got the spacers, and the tires mounted up (with the help of my daughter) this evening. Thanks too to the lovely weather we are having here in Nor-Cal...
    Looks pretty good and should really help keep the trailer stable on the road and off. Those tires are close to 3 times wider!
    Clay
  12. Newt
    Newt New Member
    18
    Jun 16, 2012
    They look awesome! You'll have to let us know how they ride (on and off road).
  13. niagarafam
    niagarafam Active Member
    2,157
    Jan 25, 2014
    I have wondered about wider tires. Is it just a matter of making sure you have clearance for them, or are there other things to consider before installing them?
  14. ccarley
    ccarley Member
    124
    Sep 23, 2014
    Clearance is a big concern, but another concern which is hard to check for is clearance when the suspension is under compression on bumpy roads. I doubt that the tor-flex axle has as much uptravel as I have clearance for, but we mostly adjusted the height of the trailer to be towed behind my (rather large) Suburban.
    If everything goes well, we'll be able to take this on a short off-road trip in April! Keeping my fingers crossed on that trip, but my Suburban still needs some work as well. Totally worth it, though!
    Clay
  15. durhamcamper
    durhamcamper Active Member
    752
    203
    Apr 21, 2010
    Pickering, Ontario
    With shorter tires, the wheels would be turning faster when towing. This means the bearings would also be turning faster......is this something to be concerned about as far as wear/heat etc or am I over thinking it? Also, tongue height to tow vehicle changes so you will need a longer drop tongue. And if the tires turn more, how much faster will they wear out?
    I like the look, and easier to inflate to 50 lbs etc though. Makes me go hmmmm.
  16. ccarley
    ccarley Member
    124
    Sep 23, 2014
    True, the short tires cause the bearings to turn fast. In this case, though, the original tires were actually about 1/2" shorter. I'm slowing them down marginally with these new tires, although probably not enough to make a difference. The originals were 5.70X8, similar height, but about 1/3 the width!
    In my Suburban I carry a high volume air compressor, so that will make airing down/up very easy as well. The nice thing (I suppose) is that if I do have a tire issue, the stock spare (well... now I have 3 spares!) will still work.
    Clay
  17. inthedirt
    inthedirt Active Member
    974
    228
    Aug 28, 2012
    SW Montana
    I've run those skinny hockey-puck tires on Harbor Freight trailers for years and plenty of miles without issue. Keep your bearings well-lubed and your air pressures up and you shouldn't have many issues.
  18. rwilliek
    rwilliek New Member
    210
    Jan 21, 2014
    My previous camper had the skinny high pressure tires on it, and that thing was all over the road - a small bump would send the camper flying.
    I have a heavier camper on wide tires and it pulls like a dream. I just ordered wide tires myself.
