WiFi and off air
Discussion in 'Campsite Electronics' started by HiFiDave, Jan 6, 2013.
  1. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
    As you know, many areas one can camp at has wi fi. Last state campground we were at had it but...our laptops didn't have the guts enough to pull in a signal. As I looked around at all the big dollar RVs I see this lil white antenna sticking up. Hmmmmmm When it's late, we like to settle down and my wife loves to share with her birding friends on facebook. I know I would sometimes like looking up a good movie on Netflix and sending it via HDMI to the flatscreen.
    So for Christmas DW got me this neat wifi repeater system. I really thought through how I was to have it quickly hook up to the trailer along with my off air antenna. I really didn't want more "set up" chores so it had to go up easy and fast as well as come down the same. So I took a spare antenna mast pole I had, put the two antennas at the top and ran the cables down through the pole to pop out of the pole right at the height where I push them through into the trailer just under our dining bench. The pole simply slides along the strap as the top cranks up and it works slick and fast. The whole antenna assembly straps to the top of the trailer on the rack nice and snug.
    I can now rotate the pole easily to aim at off air signals if I want at any local stations. The wi fi antenna works like a champ and now I can wireless repeat any signal to any laptop at our campsite. Hmmmm with the nice weather we have here, think I'll go camping! [:D]
  2. JungleJim
    JungleJim New Member
    990
    Feb 25, 2008
    Cool set up.
  3. ricko
    ricko Member
    444
    Apr 6, 2009
    Nashville, TN
    Could you share more info on the 'repeater' setup? It looks like a Linksys WRT54G with a big antenna attached... I have an extra one laying around.
    Where did you purchase?
    Thanks
    Ricko
  4. JackShephard
    JackShephard New Member
    Dec 30, 2012
    I myself would love to learn more on this setup.
  5. HiFiDave
    1,069
    Feb 1, 2012
    I wanted something that was "plug and play". I have to limit the time I fool around with things as best I can and putting the mast together etc. was about all I wanted to do. Didn't want to worry about N connectors, configuring routers bla bla bla. This setup was perfect and works like a champ. Just plug in it's IP addy, scan for open networks and you are in...
    http://www.jefatech.com/product/RV-KIT-REPEATER/Long-Range-WiFi-Repeater-Kit-for-RVs.html
  6. TX_F2
    TX_F2 New Member
    1,041
    Mar 30, 2008
    Texas
    Nice setup [8D]
    I have had to make more than one trip on past camping trips to the campground office to use the internet because the laptop couldn't pick up the wi-fi signal at the campsite. My wife also likes to post pictures to her friends during our camping trips.
    Could you post some close up pics of how the antenna slides along the strap, and how the whole antenna assembly straps to the top of the trailer.
  7. HiFiDave
    1,069
    Feb 1, 2012
    The mast is about 1 1/4" electrical emt trade size conduit. So I went the next size up minerlax or "mini" strap and attached that to the trailer. I pulled a screw out of the corner molding, loaded up some gorilla "super" glue on the threads and screwed the strap to the siding. I painted the strap black first and wrapped the sides of the strap that rubs the pole with rubber tape then vinyl tape so it wouldn't scratch up the pole paint. With the strap slightly larger than the mast, as the top goes up, the strap slides along no problem. At the bottom I used an old door from an electrical sub panel. About 14" x 10". As the door had a large center raised portion...I hole sawed a 1 1/4" hole in it and the mast drops into that for stability at the bottom. I drop a nearby rock on the lid and the base is "rock solid" LOL I'll have a pic of it strapped to the trailer roof rack tomorrow.
  8. JackShephard
    Dec 30, 2012
    Thanks for this...this should help my wife and I very well.
  9. ricko
    ricko Member
    444
    Apr 6, 2009
    Nashville, TN
    Thanks for the info... time to get my geek on.
    Looks like the DIY alternative might be an 8 or 9db antenna like one of these - http://www.cyberguys.com/product-details/?productid=51000 The same company has some directional antennas also (that point to the source).
    An adapter cable like one of these - http://www.cyberguys.com/product-details/?productid=40458
    and a router that will act as a repeater - the Linksys like the one in the pic can be re-flashed with DD-WRT to do that...
    I need to double check all the terminations to make sure the cables would all connect and figure out all the clamps... but it's do-able.
    Thanks for the idea!
    Ricko
  10. HiFiDave
    1,069
    Feb 1, 2012
    Yes, DIY was something I began to look at but I'm so damn busy with so many things that I must limit my time on such. You know, I got a spare old dish, thought about a WiFi biquad dish antenna etc, etc. etc. Uggghhhhh I just don't have time. At the jefatech site, they had struggled with direction antennas on their set up for some reason. Read something about it anyway. But DIY is very do-able indeed.
  11. Camp-N-Nuts
    Camp-N-Nuts KrustyKamper
    2,025
    Aug 9, 2011
    Central WI
  12. HiFiDave
    1,069
    Feb 1, 2012
    I looked at that one time. (or something very similar) But a USB antenna doesn't work for our needs as I have more than one device needing to connect at the same time via wireless. I needed a wifi hot spot so unlimited devices could connect at once.
  13. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    That repeater setup is kinda cool but way overpriced. A mikrotik with a stick antenna and a cat5 jumper is $100. This is what I use
    http://routerboard.com/
    Of course I don't have the off air setup.
    Think Outside !- No Box Required.
  14. Camp-N-Nuts
    2,025
    Aug 9, 2011
    Central WI
    But it may for someone else! [:D]
  15. HiFiDave
    1,069
    Feb 1, 2012
    Yeah, I knew it was more cost than going some other ways however, it was less fooling around than some other ways and that is exactly what I needed. Package deal, plug and play. Thought it might be the same for some other folks...
  16. Hacksaw
    1,875
    Aug 23, 2009
    And it works good for you...all that matters, I just put out the info so others have options.
  17. br9
    br9 Member
    740
    May 16, 2008
    Fort Worth Tx
    That's a really nice setup.
  18. highside pup
    highside pup Active Member
    2,723
    Feb 26, 2012
    Really nice but how well does it work?
  19. Nascar Fan
    Nascar Fan Active Member
    1,510
    Nov 18, 2008
    Washington, PA
  20. highside pup
    2,723
    Feb 26, 2012
    Actual range?
