will it tow it??
Discussion in 'Tow Vehicles, Hitch & Towing' started by heritagechris, Jun 4, 2011.
  1. badhabit1
    badhabit1 New Member
    38
    Aug 8, 2010
    No, you still need a tranny cooler for towing! Engine oil cooler and tranny cooler are completely seperate coolers. Get the biggest tow vehicle your budget will allow.
  2. papachaz
    papachaz New Member
    2,821
    Jun 26, 2011
    thing to remember about a TV, GVWR is total weight of EVERYTHING, as already said, that includes people pets gear fuel.....
    someone said something about a short wheel base vehicle, actually the shorter the TV, the easier it is to back. I've pulled an older model 24' travel trailer with my K-5 Blazer and it did great! the important things to remember, BRAKING. unless you have a tow package on any vehicle, you have standard brakes. a vehicle with a tow package usually has better braking, but a brake controller is EASY to install and use.
    the other thing is, a weight distribution hitch and sway bar is a GREAT investment, and is well worth the investment, unless you have a 3/4 ton or higher rated TV. and even with one of those, if you're pulling a heavy trailer, the sway bar and weight distribution will help.
