Will Residential Faucet Work?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by niagarafam, Aug 16, 2015.
  1. niagarafam
    niagarafam Active Member
    2,158
    Jan 25, 2014
    Can I change out our plastic sink faucet for a "residential" metal one? I getting help with this under plumbing, but did not get help. I know it has to be low profile. Anyone?
  2. bropaul
    bropaul New Member
    4,830
    Aug 7, 2009
    I replaced ours with a laundry tub faucet from Home Depot. Center to center distance was a little longer so I had to elongate the holes a bit for the stems to drop in.
    Paul
  3. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
  4. bropaul
    bropaul New Member
    4,830
    Aug 7, 2009
    Bathroom faucets are 4" centers but usually have stationary short spouts. I found the laundry tub faucet (also 4" centers), which was all metal, with a longer, moveable spout ... so I could easily fill pitchers or wash larger cookware. (Happy wife! [;)])
    Diane
  5. niagarafam
    2,158
    Jan 25, 2014
    We also need it to have a threaded removable aerator. We remove it to connect our reverse osmosis filter system; we use it to make our drinking water.
  6. tenttrailer
    3,163
    299
    Jul 18, 2013
    Thornville, OH
    I changed our kitchen faucet with one with a sprayer
  7. bondebond
    bondebond New Member
    2,079
    Aug 14, 2008
    The short answer: yes.
    There's nothing special there to prevent you except space around it.
    You can go with an RV faucet that gives you a tall neck but it screws off when you pop down. I stopped taking mine off once I realized my beds slide in but don't hit the sink.
  8. Heartman_wa
    Heartman_wa Active Member
    1,703
    Mar 5, 2006
    Tacoma WA.
    You can use a Bar faucet. Check the height you may even be able to use a high neck style.
  9. StPeteClipper
    StPeteClipper Member
    65
    Jan 3, 2015
  10. niagarafam
    2,158
    Jan 25, 2014
  11. swordfish
    2,209
    37
    Sep 27, 2010
    My neck is removable.
    I bought the new high rise to replace the original and only swapped the neck.
