Window Air Conditioner Installed
Discussion in 'Camper Restoration Projects' started by sharpedev, Mar 14, 2016.
  1. sharpedev
    sharpedev New Member
    19
    Oct 14, 2015
    So this was a busy weekend doing my first camper mod. After reading for weeks about all the different ways to install a window air conditioner in a camper, I decided to go the in-cabinet route. Here are some pics. I've built Styrofoam channels for the outside air to circulate properly, as well as added an exhaust fan to ensure all the hot air escapes efficiently. Lastly, I installed an angled Styrofoam piece under the unit, to direct any condensation out the vent outside. I'm pretty proud of getting it to turn out decent, especially since I'm not really a carpenter or anything.
  2. TRR
    TRR Active Member
    453
    224
    Nov 3, 2014
    Alabama USA
    Wouldn't mind seeing a few more pics of the Styrofoam channels, exhaust fan, and drip control.
  3. MickeySp
    MickeySp Member
    107
    Apr 2, 2015
    Well done, looks like it belongs there!
  4. Oranges Rhymed
    Oranges Rhymed Member
    166
    Mar 4, 2011
    Ditto! This is the first window/wall unit install in a pup that I've seen that doesn't look goofy as everything. Congratulations!
  5. nineoaks2004
    8,065
    3,600
    Dukes, Fl
    Looks really good, It should keep you nice and cool, I had one that was installed at the factory similar,
    I had to make a vent that attached to the lower front and funnel the air upward toward the ceiling, it worked really good.
  6. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
    Smart thinking, I could dump my cooler to add a ac unit in its place. I would love to see the rest of it
  7. sharpedev
    19
    Oct 14, 2015
    Wow, thanks everyone! I didn't expect such a positive response. :)
    I'll take more pictures of the "ducting" I put in place and post it when I can.
  8. molanginaeda
    molanginaeda Member
    241
    Sep 26, 2015
    Very nice. This actually let me rethink my AC installation. Why spend $600 to get a rooftop AC while a $99 windows AC can do the same task.
  9. Haybale
    2,509
    338
    Aug 22, 2013
    San Diego via MN
    That looks great, I would remove the yearling decal though, I like that way!!
    Window units are not as robust and wont last long with bouncing around on a road and such. However if mounted with rubber or some sort of vibration dampener it will prolong the life.
  10. sharpedev
    19
    Oct 14, 2015
    Yeah, I had considered getting a roof-top too, but I had a hard time getting over the idea of cutting a hole in my perfectly seamless roof, and spending $600 on an A/C when I bought this one for $50 from a friend of mine. I tried to combine the best ideas I've seen online, and the total install cost me less than $100.
  11. sharpedev
    19
    Oct 14, 2015
    Yeah, I need to remove the top-half of the Yearling sticker, but I knew that could wait until later. I mounted my A/C in pretty well, but you could be right in that the bumps of the road might take it out of commission earlier than normal, but at $50 cost for the unit, it's hard to complain!
  12. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
    Well, you may wish to do your home work on this. I'll put a Coleman Mach roof mount A.C. up against a floor mount cheap 99 dollar A.C. (not engineered for bouncing around) all day. It will cycle less, cool much better overall. The A.C. at the floor has to work it's ass off because, well, cold air sinks. Having your A.C. up high cools the space much better and requires a smaller unit to do the same job. (Especially in a tent!) I don't have an A.C. on the roof, hate the thought of cutting into a nice roof like I have. In my business as an electrician/electrical contractor...if you can avoid a roof penetration at all, do it! If I do A.C. ever, doubtful, I'll only do this unit https://www.pplmotorhomes.com/parts/rv-air-conditioners/coleman-mach-8.htm
  13. silvermickey2002
    4,781
    561
    Sep 11, 2008
    Morris County, NJ
    We have the Coleman Mach 8 and love it...Yes, it was a hard decision to cut a hole in a perfectly good roof!!!
    Nice install on the window unit.. [;)]
  14. money pit
    money pit What could be so bad??? We are camping!!!
    613
    Oct 5, 2014
    You know I am not one for MOST of the home window unit installs on PUPS, but dang you thought that out very well and like most of the other responses it looks very nice and I would go as far as saying it looks like it belongs as a factory unit when the pup was built! GREAT JOB! please keep us posted on the final details and how it works and if you had to do any changes once u get it out in the field.
  15. EvilM0nkey
    EvilM0nkey Camping fo free!
    217
    Jan 11, 2011
    I'm not so sue this was a great idea to be honest. I think you're going to find that you'll end up with poor performace due to a lack of proper airflow in the back of the unit. Not to mention the water damage you're going to have from the condensation dripping out and being slung by the fan. You've also created a very hot box around the unit. Not to mention your unit has to get fresh air into the back as well.
    I hate to burst your bubble. But it's better you find out now!
    My air conditioner will sling water everywhere on a humid day from the outside.
    I did something similar but mine is outside.
    [​IMG]20150720_183154 by Ross, on Flickr
    [​IMG]20150718_222701 by Ross, on Flickr
  16. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    18
    Jul 10, 2012
    I think it looks incredible. Enjoy the cool air. Don't let the engineers scare you. Just keep an eye out for water, but it sounds like you got it covered.
    Nice Work.
  17. Fordiesel250
    Fordiesel250 Member
    570
    22
    Mar 28, 2010
    Nice job and looking forward to follow up pictures
  18. sdn40
    sdn40 Member
    82
    Jun 3, 2008
    Love the concept and have been pondering the same concept for years.
    Some concerns voiced here are valid. Lack of air flow on the back of the unit will cause some issues I believe. There is another thread somewhere where something similar was done and airflow was blown across the back of the fins to solve the problem. This person built a special box for the unit. I'll try to locate it and post back.
    Here it is: http://www.popupportal.com/index.php?topic=41338.0
  19. shuang2
    shuang2 Well-Known Member
    1,187
    98
    Apr 20, 2010
    Nice job, we have a window unit too. It's work pretty well on our trailer! Love those window A/Cs!
  20. shardtke11
    shardtke11 New Member
    145
    Apr 7, 2016
    Looks great! My DH put a window unit in our 1st pup and it worked well. Your installation looks great!
