Wiring in a '95 Bonair BA 700
Discussion in 'Wiring' started by timothias, Mar 31, 2013.
  1. timothias
    timothias New Member
    69
    Mar 31, 2013
    So, looking at my NTU PUP, I noticed something unique and confusing on the tongue.
    Seven pins in a connector on the tongue, into which plugs the seven wire harness beside it.
    The confusing part is that the other end of that harness is this 4 flat connector.
    Any ideas what may be going on here? I haven't yet stripped off any tape to trace the wires, and haven't followed them into the PUP either. I would assume this would be a seven pin wiring for trailer brakes and charge etc, but the PUP is not equipped with brakes.
    Thoughts? [?:~{]
  2. mnebinger
    mnebinger Livin' The Dream!
    1,213
    Jul 22, 2012
    It looks like someone in the past removed the original plug and replaced it with a 4-flat.
    If the trailer doesn't have brakes and you don't need the charge line then don't worry about it, as long as all the lights work.
