Wiring portable radio to 12v battery
Discussion in 'Campsite Electronics' started by capslock118, Jan 17, 2013.
  1. capslock118
    capslock118 New Member
    25
    Jun 25, 2012
    For Xmas I received a cute radio that can take ac power or run off 2 d batteries.
    You might say this is sufficient....but I'm kind of a Tim the tool man Taylor... Interested in doing things my way but will probably screw it up and cause a fire.
    What I'd like is, rather than carrying around single use d batteries for my radio, instead run off the 12v deep cycle battery I have on my pup.
    Obviously using the ac plug would not work. Im thinking I'd need something that will step down the volts from 12 to 3 volts. And I only assume three because it takes 2 d cells.
    I'm at a loss on what that part it is I need, the part that would do the step down. A fuse wouldn't do that, fuses concern amps. Can anyone flash a light in the right direction?
    Sent from my Nexus 7 using Tapatalk HD
  2. bondebond
    bondebond New Member
    2,079
    Aug 14, 2008
    For $18.95, you too can own the PowerStream DC to DC voltage converter found here.
    12 volt to 1.5V, 3V, 4.5V, 6V, 7.5V, 9V Volt DC/DC Converter and uses a standard 12 volt cigarette lighter plug for the source voltage. I just did a Google search on "12 volt to 3 volt" and came up with that. I've never used it or anything of the sort so I can't say how effective it is.
    Just add a 12 volt outlet like this if you don't already have one and that keeps it pretty simple.
