Wondering about my HP port on Coleman UTAH
Discussion in 'Propane - Got Gas' started by myride, Dec 20, 2017.
  1. rabird
    6,582
    258
    TX
    16 psi is unique to the HP exterior stoves on some coleman trailers (after they stopped using Coleman stoves???).
    Those unregulated stoves operated via 16 psi propane. A 15psi or 20 or 30 would work fine for almost any regulated appliance or an adjustable one.
    FWIW, I got a baby Q to operate fine off my regulated low pressure outside port, another stamped metal little grill worked but turning it from low to med to high caused no change in the tiny flame. Both were with the grill's original regulated still attached. Tried a portable buddy heater with reg intact, fluttered and did not operate well.
  2. myride
    myride Well-Known Member
    842
    378
    May 14, 2015
    Edmonton, AB
    UPDATE.....thanks to all for your help.
    The "steaksaver" seems to have done the trick, I also added a valve in line so I can hook up line, turn on propane before setting up trailer. It runs a tad lower than I would have liked but feel safer than the way she was running previously.
    Again, thanks to all.
    BelchFire likes this.
  3. ice_nyne
    ice_nyne Member
    40
    Jun 22, 2010
    Myride, glad you were able to fix your issue. I am battling something similar. Mind posting a pic of your solution?
  4. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    It will be a little while before I can post pics....still in storage but....HP port on trailer frame I attached a "steak saver" coupling, then to that a check valve and a quick connect....works fabulous. The reason for the check valve is once you screw the steak saver onto port it free flows until you connect the stove or quick connect....this way I just shut valve, connect....connect stove via quick connect and turn on valve.....voila.....
  5. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    Here's what you need,
    1- steak saver that goes into HP port on side of trailer, I then use the Camp Chef hose supplied with the stove but added a quick-connect with an on/off valve....reason being once you screw the steak saver into place it will spew propane unless you have a way to shut it off......I leave this whole assembly together preventing leaking propane while attaching. From there I added a 10 ft hose with the male quick connect on one end and the standard filling on the other for the stove......
    Won't let me upload image...file too large
  6. Sjm9911
    3,934
    1,955
    Ok so the steak saver valve goes from the HP port to reguler bottle? For us idiots. If so i may have to get one.
  7. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    No...steak saver screws to trailer HP on frame of pup......this allows you to then use the regulator connector suplied with you stove.
    All Coleman trailers had either the screw type HP or the quick connect LP.......this rig is to allow you to run your camp chef or other stoves from an HP connector on trailer frame
    Make sense?
  8. Sjm9911
    3,934
    1,955
    Yes, got it. i need to find a conection for my blackstone. I bought a line but cant find it now, lol.( i blame amazon). Also was looking to split it for a propane fire pit, sacrilege i know. But last trip and the wet wood made for smoked marshmallows. So , we wernt happy campers.
  9. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    Complete set up
    Steak saver on trailer w/ stove regulator attached 2019-07-09_19.24.16.jpg
    Here's the important end....
    Make sure you have a valve on quick connect to prevent propane loss when hooking it all up
  10. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    Don't know if they make a splitter or not you could use.....somebody must....lol
  11. Sjm9911
    3,934
    1,955
    Lol, thats an interesting set up. I allready put a shut off valve in line with the gas. I do know if that spring clip shut off in the original fails, its a mess. And its even harder to get a replacement as its a reverse thread. Ty for the pic.
  12. rabird
    6,582
    258
    TX
    myride and Sjm9911 like this.
  13. Sjm9911
    3,934
    1,955
    That should work. Ty.
  14. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    ..so you carry a spair....lol
  15. Sjm9911
    3,934
    1,955
    I should have , it took me like 2 months to track one down. The first one wouldn't screw on. Then after looking at it ,i relized the old was reverse threaded. Then ,i went to all the welding guys, after the guys that arually make propane lines couldn't help , because its a welding thread. What a pita. I cut the brass line and re flared it , putting in a gas shut off. So if it brakes again, i dont have to replace it.
    myride likes this.
  16. myride
    842
    378
    May 14, 2015
    Edmonton, AB
    ....always a work-around! Problem solved...:)
