Would you like your cell phone rare,medium or well done?
Discussion in 'Campsite Electronics' started by Detroit_Iron, Sep 15, 2014.
  1. Detroit_Iron
    Detroit_Iron Active Member
    512
    25
    Jan 31, 2013
  2. Snow
    11,105
    1,768
    Neat gizmo if your on a backpacking/canoe camping trip ... don't really see the use for it if your with your trailer, even boondocking most of us have chargers in the vehicle ...
  3. swordfish
    swordfish Well-Known Member
    2,218
    41
    Sep 27, 2010
    It is very cool regardless. Wonder how long it takes to charge up a drained cell phone. Also it should work with propane fire since all it needs is hot water or is there more to it?
  4. Ponyknite
    Ponyknite New Member
    126
    Jul 6, 2014
    Is it a thermoinduction motor or is it stream or some other thermoelectrical properties that I haven't heard of? May the reverse of solidstate heat pump?
  5. StageLover
    StageLover Member
    199
    May 20, 2010
    Vancouver, BC, Canada
    Looks like reverse Peltier effect. Peltier effect is used in coolers such as the Mobicool. Running a current through the Peltier Effect device causes one side to heat and the other side to cool. The Mobicool uses this property to cool (or heat depending on switch setting) the contents.
    The opposite behavior is also possible: heating or cooling one side relative to the other side will generate a current. This appears to be the basis of this device. It looks like the red 'chimney' provides the cooling for the other side of the device.
  6. Strut
    Strut Member
    250
    Jun 24, 2014
  7. generok
    2,958
    1,368
    Feb 7, 2013
    Anchorage, AK
    If it had a video of someone hooking the unit to a PUP battery in a boondock setting, I'd bet it would fly off the shelves. Granted, this, and similar units, only produce 2.5 watts, but like Snow said, I have a gigantic battery charger built in to my TV... it's called the alternator and it provides current to PUP batteries, phones, GPS and even inverters quite nicely with the turn of a key. And, it is 50 states emissions legal and quiet.
    But, if you were to spike out from the PUP and TV, then this is a way to generate a little charge with something most people do anyway... have a fire. And for that, I say, it's pretty good. Yeah, yeah, get away from the office, leave your phone behind... my phone has the BEST GPS navigation tool I've ever seen, as well as the ability to download maps, take pics, etc. My phone is a tool, and it needs a charge to work.
  8. Strut
    Strut Member
    250
    Jun 24, 2014
    My parents have a thermo-electric(Peltier) powered fan that circulates air around their woodstove.
  9. Jeepguy93
    Jeepguy93 Active Member
    504
    42
    Mar 30, 2014
    MA
    It's pretty much how the Mars rover curiosity runs, it uses a nuclear generator that creates heat instead of fire.
  10. BelchFire
    1,694
    414
    Mar 29, 2012
    SE Georgia
    Did anyone else get a security warning off that link? Looks a like bogus site certificate.
  11. WeRJuliIan
    906
    91
    May 15, 2014
    Sarasota, FL
    Not exactly Peltier... That's where you run current through a bimetal "couple", and it transfers heat from one junction to the other.
    The opposite process, applying heat to generate current, is the Seebeck Effect.
    Many decades ago, I worked for A Certain Government Department, and part of the job was reverse-engineering odd bits of technology to see how they worked. We were once given a hurricane lamp containing a thermoelectric generator, intended to charge the batteries on a covert radio without attracting attention.
    Figuring it out was made a little more tricky by the bullet hole...
  12. StageLover
    StageLover Member
    199
    May 20, 2010
    Right, Seebeck. I couldn't remember the name so I just said a kind of reverse Peltier. I happened to remember "Peltier" because I had been explaining to a friend how the Mobicool on our boat worked. I should have taken the time to look it up.
    No problem here with the site certificate. It is a GoDaddy certificate so maybe your browser doesn't have the GoDaddy authority registered.
