Wow! Another Fleetwood Lift Problem...This Forum is Busy!
Discussion in 'Lift Systems' started by alexmacsuga, May 24, 2010.
  1. alexmacsuga
    alexmacsuga New Member
    26
    Mar 2, 2010
    /Users/alexmacsuga/Desktop/IMG_0249.jpg
    This part is not working. I put the crank handle in here, and it just spins and spins. Won't crank up at all. When I put a socket wrench inside, I can crank it up with no problem. Bringing it down using this socket method is sure interesting!
    How can I get this part to stop turning in its housing?
  2. Tryton
    Tryton New Member
    17
    Jan 8, 2003
    Your URL is bad. Looks like it pasted the last half.
  3. alexmacsuga
    26
    Mar 2, 2010
    Here's the picture! Can anyone help?
  4. cuckoo
    cuckoo Active Member
    1,816
    Sep 7, 2009
    Okeechobee, FL
    Alex you should have a pin spanning those two holes.... Just my assumption... That would be what your cranks slots fit over. I could be totally wrong, but should be right. Shouldn't it have a roll pin there?
  5. alexmacsuga
    26
    Mar 2, 2010
    Right! I am not that much of a newbie, Frank! Give me a little credit! I have the pin out now because the only way I can crank it up is by putting a 9/16 socket inside there to get it up.
  6. cuckoo
    1,816
    Sep 7, 2009
    Okeechobee, FL
    Hmmm... Ok you get credit.... [:D]
    Our system is different without the chain...
  7. alexmacsuga
    26
    Mar 2, 2010
    Thanks! Could the threads on this part be stripped? I can't seem to tighten this as much as I would like.
  8. grcooperjr
    grcooperjr Lunatic
    1,520
    May 21, 2007
    Tigard, OR
    Hi Alex....
    Did you by chance lube the sprocket, If you did you may have gotten a bit of lube on the clutch disc.
    That would cause the exact same condition that you explain. Here is a pic of the clutch disc on mine. Yours uses the same approach
  9. Davylee
    Davylee Camping = Life is Good
    1,823
    159
    May 4, 2009
    Maine
    I had the same problem but I don't have the chain part. It was the spacer and spring in the handle extension assembly that was bad. If you can crank it up with the socket and down then the problem is not the whiffle tree. Does it stay up once you crank it up?, does it still make the ratcheting sound while cranking up?
  10. alexmacsuga
    26
    Mar 2, 2010
    Yes, it still makes the ratcheting sound when cranking it up. Also, I have been successful in cranking it up with the socket, and it stays there. That's a good thing! I need to do it a few more times before I am comfortable with it.
    What do you mean about the spacer and spring? I found a couple of washers in there and a spacer, but no spring. There was something that resembled a spring, but it was flat. It looked liked a few of those lock washers all smashed together.
  11. Davylee
    1,823
    159
    May 4, 2009
    Maine
    Yes, that is/was the spring it looks kind of like some washers welded together and is around .25" think or so if I remember correctly. It is not too flimsy so if this is flat then then I would think that is your problem. When you use the socket do you have to push in on it or do you just turn it normally? Use this site http://www.fft-inc.com/korkwerks/parts_books.htm to identify the parts. You don't say which trailer you have, so I couldn't link right to yours.
