you use Bearing Buddies?
Discussion in 'Tires / Brakes / Bearings / Axles' started by partsjay, Mar 23, 2012.
  1. partsjay
    partsjay New Member
    49
    Aug 26, 2010
    Just curious how many of you use them? When I bought my hubs and bearings, the Guy at the Parts Counter said I shouldn't need them, and that they are mostly for Boat trailers.....any thoughts?
  2. mgeiger
    mgeiger New Member
    146
    Apr 12, 2011
    I had an extra set from my boat trailer and put them on. They can't hurt. Just don't overfill them.
  3. Flyfisherman
    Flyfisherman New Member
    3,682
    17
    Mar 4, 2003
    Shallotte, North Carolina
    I have the Bearing Buddies on the boat trailer, which they were designed for. On my last Starcraft had the E-Z Lube Axle, different from the Bearing Buddies. Personally, I would not want the Bearing Buddies on a tent trailer, unless I was going to be backing it into water.
  4. Raycfe
    17,811
    3,294
    Bearing buddies should not be used with trailers with brakes, and are designed to force water out of the bearings on boat trailers. Not needed on PUP's. Just my [2C]
  5. chipperone1
    chipperone1 Member
    386
    Aug 27, 2011
    I have EZ Lube axles - very good to me. When used and maintained properly "Bearing Buddies" are very good - most don't get it right and have probs.
    They are compatable with all axles/brakes if used correctly.
    Are "Buddies" designed to "force water out"? I would think they are designed and function as to prevent water from entering in the first place! Makes more sense to me - they create positive pressure because of the spring - one psi or so - enough to keep water out.
    Use them if you want to - correctly of course - it couldn't hurt. You don't NEED them however.
  6. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    Bearing buddies are the worse thing that you could do. All they do is make a mess of grease and cause braking problems.
