Your recos for newbie with 2 boys and Outback 3.0
Discussion in 'Camper Pre-Purchase Questions' started by Jean-Pierre Tanguay, Feb 18, 2018.
  1. Jean-Pierre Tanguay
    Jean-Pierre Tanguay Member
    52
    Feb 18, 2018
    Quebec, Canada
  2. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,745
    May 8, 2011
    Florida by way of WV and MD
    You can always add an electric dorm fridge fairly cheap. We took out our 3-way fridge and replaced it was a freezer. We have a large dorm fridge w/freezer sitting on the counter. You will likely run into pup fridges all about the same size unless you move into more pricey high wall campers.
    The one pictured appears to be very well kept.
  3. jnc
    3,931
    1,193
    Oct 1, 2014
    South Central New Hampshire
    Somewhere on the Portal there is a checklist for things to inspect before buying you should try to find it or maybe someone can post it here for you.
    The only thing I noticed in the pictures was that the curtains were worn. That being said it seems to check all your boxes. I think when all loaded up with kids & gear you will be close to your weight limits So you will need to be mindful of how much stuff you bring.
