BillyMc
You could use a disconnect and take the 240v breaker out. Put a 110v 30 amp on one side to supply your current power center and single pole tandem breaker on the other side for two 15s, two 20s, or a 20 and a 15. $20 for the box plus breakers, wire, outlets, and 4-pole supply cable all that you going to need anyway. My choice would be a tandem 20-30 on one side and a 15-20 on the other. This would give you two 20 amp circuits and one 15 amp circuit in addition to what you already have at a low cost and not very much labor.
